Old 07-28-2006, 09:08 PM
mycobra70la mycobra70la is offline
horn location
94 mustang- is it inside drivers front fender and where to access
Old 07-29-2006, 12:11 AM
reekor reekor is offline
Re: horn location
Horn Mounting Location
Both horn assemblies are mounted in the LH wheel well on a common bracket.
Horn Assembly
Removal and Installation
Disconnect the horn wire from the terminal and remove the retaining screw. When installing a horn assembly, tighten the retaining screw to 8-12 N-m (6-8 lb-ft).
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 07-29-2006, 12:53 AM
Re: horn location
Okay everything is connected. What is the next most likely thing that could cause the horn not to blow.
Old 07-29-2006, 10:00 AM
Re: horn location
Possible Source(s):
§ Circuitry open/shorted.
§ Horn relay.
§ Horn blow switch.
§ Horns.
