Old 07-28-2006, 05:39 PM
Im3good4u's Avatar
Im3good4u Im3good4u is offline
Oil?
Hey guys i know this has been posted over and over again, but i have a quick question i was reading the manual and in the oil part it said NOT to use SAE 20-50w, or 15-50w. That happens to be what i've been using. My car has 125k miles and about 35-40k since the rebuild. I live in Miami and the temperature is always above 75 degrees. My dad says that i should stick to that oil because my car has alot of miles andin this temperature the oil gets very thin. Should i change back to 10-30w(Recomended by manual) or stick to what i've been putting in there I've been going that thickness for about 4 months.
1998 Trans Am Bone Stock...For Now!
Sold 2004 Dodge Ram 1500 QC Hemi W/ K&N Air Filter, Superchips Tuner.
Sold 1994 Firebird Formula W/ Hooker Headers, Magnaflow Exhaust, Ram Air, Fuel Pressure Regulator.
Quiters don't win, Winners don't Quit.
Old 07-28-2006, 07:50 PM
Mr. Luos's Avatar
Mr. Luos Mr. Luos is offline
Firebird Guy
Re: Oil?
I know some guys with built motors with insane tolerances that almost have to run that thick of an oil to prevent burning a ton.
Stick with what works.
Motor quieter with the thicker stuff?
What differences between the oils when you drive?
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
Old 07-29-2006, 07:12 PM
Im3good4u's Avatar
Re: Oil?
Motor is quieter...and the difference is felt off the line...the car definitely takes off quicker, and you feel it at the beg. of each gear as if the car had something holding it back. Higher RPMs i couldnt tell the diff.
Basically Thin oil u get better fuel economy and higher HP and thicker means alot less wear but you suffer on the other two, I really cant say how much of a diff it causes.
Old 08-13-2006, 08:23 PM
DarkblueTA's Avatar
DarkblueTA DarkblueTA is offline
Send a message via AIM to DarkblueTA
Re: Oil?
I live in Palm City(30 miles north of West Palm) and I run Mobil 1 10w30. Unless you are highly modified or sit in a lot of stop-go traffic, I'd stick with 10w30.
DarkblueTA
GT70, FMIC, Alky-water injection, Hooker Cat back, 208/230 .549/.579 121LSA Cam, forged diamond pistons/eagle rods, LS6 block, Lakewood LCAs, BMR STB/PHRB/Sway Bars, poly torque arm bushing, Spec Stage 4i clutch, B&M Ripper Shifter, SLP Subframes, 60# injectors, KYB AGX shocks/struts, Moser 12 bolt(373 gears, 33 spline axles, posi, ta girdle/etc/etc/etc) and HPTuner kit
2007 Nissan Titan Daily Driver. 2* advance
Old 08-13-2006, 09:59 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: Oil?
I use Mobil 1 10W30 or mobil 5W30.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 08-13-2006, 10:50 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Re: Oil?
If your that worried, start running a 10w-30 synthetic with seal conditioner.
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 08-14-2006, 10:22 AM
hotrod_chevyz's Avatar
hotrod_chevyz hotrod_chevyz is offline
Re: Oil?
Ive always ran 20/50 quaker state. never had a problem.
If i run 10w30 in the crown vic, the motor rattles at the top of first gear and it smokes out the tail pipe. It also burns the 10w30 up, and ends up low on oil. 20w50 doesnt burn up like that, and it barely smokes out the tail pipe.
BTW ive driven the car for over 70 thousand miles now, and it runs better than when i bought it. It goes through battery posts frequently though. 10w30 is thin as water and does very little to protect engine vitals, by the time 3,000 miles has passed. 20w50 is as thin as 10w30 after 3,000 miles.
Certain instances do call for lighter oil, like cold weather, certain engines with external oil pumps or turbos, but for the most part, 20w50>10w30.
On another note, my dad bought a ford ranger brand new. He has ran 20w50 in it since birth. 150,000 miles later it still runs perfect. It has a v-6. My sister has a 2002 ford escort. The top end of the engine was always noisy since she bought it brand new. especially when it was cold. The noise out of the rockers made me wonder what was going on. Then i noticed that every one of those 2.0's do that. Its the factory recommended oil viscosity. It called for either 10w30 or 5w30. As soon as I thickened the oil up, the noise stopped. Sounds better at 70,000 miles, than it did when she bought it with 200 miles on it.
Old 08-14-2006, 04:02 PM
DVS LT1 DVS LT1 is offline
Re: Oil?
I ran 15w50 Mobile1 for two summers - my car ran really hot back then, was burning oil, and also had a small leak, so I figured the thicker the oil would help.
Can't really say I noticed a difference in performance. If/when I have a motor that runs COLD, I'd probably go with a 5W30 Royal Purple or Mobil1.
Old 08-15-2006, 12:19 AM
97cavalier's Avatar
97cavalier 97cavalier is offline
Re: Oil?
right now i have mobil1 clean 5,000 in mine, but normaly i either run that, or castrol gtx.
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 08-15-2006, 10:20 PM
Re: Oil?
I've got clean 5000 in my engine now, but I liked castrol syntec better...
