Old 07-28-2006, 11:21 AM
Vtec95Civic Vtec95Civic is offline
Issue with my e-brake..
I got my brakes adjusted/tightened/replaced.. whatever you call it. When I got it home again I realized the e-brake had a lot less travel to it, figured 'ok, they just tightened it'. Fine.
It's been about a year now since I got it done and this problem has just been getting worse. When I disengage the e-brake, the light stays on. I have to really slam it down to get the light to go off. If I go over bumps or take sharp turns the light will sometimes (read: usually) come on, at which point I press down on the e-brake and it goes back off. The brake itself never engages, just the light.
Old 07-28-2006, 12:51 PM
polacek's Avatar
polacek polacek is offline
Re: Issue with my e-brake..
Anything in the way of the handbrake, fries/straws/condoms, etc between the e-brake and the frame that would inhibit travel?
Old 07-31-2006, 10:11 PM
Nope. Seems almost like an air bubble or something...
Old 08-01-2006, 12:35 AM
polacek's Avatar
The emergency brake is just that. It is a direct line to the rear brakes. The E-Brake does not use the brake master cylinder. You can adjust the travel underneath the car.
Old 08-01-2006, 02:19 AM
hondacivic99sivtec's Avatar
hondacivic99sivtec hondacivic99sivtec is offline
Send a message via Yahoo to hondacivic99sivtec
the ebrake is just a cable that goes to the brakes. master cylinder isn't even invovled. get your cables adjusted again
-tony-
2000 honda s2000
Old 08-01-2006, 10:22 AM
polacek's Avatar
Hey hondacivic99sivtec, I think I mentioned that the E-Brake does not use the brake master cylinder.
Old 08-02-2006, 12:24 AM
heere is this better...
i agree with polacek.
-tony-
2000 honda s2000
Old 08-02-2006, 11:53 AM
polacek's Avatar
It's all good
Old 08-03-2006, 03:59 AM
lol
-tony-
2000 honda s2000
