Old 07-27-2006, 06:16 PM
Jayson62's Avatar
Jayson62 Jayson62 is offline
Old Model Break down
Hey I was wondering if anyone has any tips on how to "break" or "deglue" a model that has already been completed? the model is probably 12 years old and my dad just put it together so its still in the green molding color. I wanted to take it apart and paint it for a new model. So any tip?
Old 07-27-2006, 09:47 PM
MidMazar's Avatar
MidMazar MidMazar is offline
Re: Old Model Break down
De-Glue from your local hobby shop.
In Progress
Old 07-27-2006, 09:49 PM
SteveK2003 SteveK2003 is offline
Send a message via AIM to SteveK2003 Send a message via Yahoo to SteveK2003
Word it mineral spirits will disolve the cement, and I hear soaking the model in water and then putting it in the freezer will help loosen the joints (The remaining in the cracks expands, and the cold makes the rest brittle). I also heard microwaving the model will soften the glue. I haven't tried any of those methods, just read about them.
I found the best method to be just prying, poking, and scribing to break as much apart as possible.
Old 07-28-2006, 01:00 AM
quadzero's Avatar
quadzero quadzero is offline
I'm always recycling old kits and parts and this is the method I use. It's really not that hard as it sounds. Usually the parts come apart quite easily.
Old 07-28-2006, 03:28 PM
Jayson62's Avatar
thanks guys i will try that.
Old 07-28-2006, 06:24 PM
Yes, I find it best to avoid chemicals if at all possible. If the model was a glue-bomb, the parts will still be damaged when you remove them that way, and if not, the chemicals might still affect the plastic.
Worst-case you just cut or break the part off and use a 1mm drill and some styrene rod to make new 'pins' to hold it in place.
