Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 07-27-2006, 05:02 PM
rcobar rcobar is offline
Red face Suburban 99 just die
I was running on the freeway (65 mph) then my 99 Sub just die.
I had check all the fuses, the fuel pump relay and everything seems to be ok. The fuel pump make the working noise when I turn the key to the On position. I had changed the fuel pump today to see if there is a problem on it but still not starting. But when I put some starting fluid on the intake (is the 5.7 vortex) the engine starts and works for couple seconds.
Where could be the problem?
Old 08-02-2006, 06:39 AM
zirb zirb is offline
Re: Suburban 99 just die
See if you got fuel pressure at the test port. It is on top of the intake by the firewall. You should have 50-60 psi. Fuel filter?
Old 08-03-2006, 12:13 PM
BURBAN18 BURBAN18 is offline
It may be the theft deterrent system, we had similar problem on our 99 Tahoe.
1999 Suburban
18" rims
Dual exhaust
