Go Back   Automotive Forums Car Chat > Mazda > MazdaSpeed
Old 07-27-2006, 01:11 PM
turbocharged420 turbocharged420 is offline
2003 mazdaspeed protege problems
im having problems with the car stumbling in gears 4 and 5 and now it seems like the turbo isnt even kicking in. it kicks in on gears 1-3 but as soon as i get to 4th gear and floor it the rpms dont even move its like stuck and cant get past 4th gear. if anyone knows any ideas or solutions to my problem please write back or email me at [email protected] thank you
Old 12-14-2006, 02:29 PM
mazdatekchubyninja mazdatekchubyninja is offline
Re: 2003 mazdaspeed protege problems
do you have any check engine light on. check for boost leak. best thing is
to put a boost gauge on and check what the max boost is. stock it should
run around 5-6 psi. you might be hitting boost cut. these cars aren't that fast to start with.
Old 05-19-2007, 05:56 PM
UnNatural Inc's Avatar
UnNatural Inc UnNatural Inc is offline
Turbos don't "kick in" like a switch... they spool up (which is created by the exhaust gas)
Turbos would also have nothing to do with what gear you are in. They are load and rpm based, not gear.
Do you have a boost gauge in the car yet?
UnNatural Inc.
UN MySpace
