Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 07-27-2006, 12:06 PM
Decipha Decipha is offline
removing 4.6L trany shift linkage
I swapped out a 4.6L engine from a 91 Crown Vic into a 93 Licoln Town Car. Now I have a problem with the trany linkage. On the Lincoln the link goes down, on the crown vic it went up... does anybody know how I may go about removing it? I'm not sure if I'm calling it the right name or not, it's the bracket that selects the gears on the automatic trany. It has what looks to be a sqaured nut on the end of it. I can't figure out how to remove it for the life of me... please help
sry mods i'll try 2 b good
Old 07-27-2006, 12:36 PM
Towncar's Avatar
Towncar Towncar is offline
Re: removing 4.6L trany shift linkage
Sounds to me like the "(TR) Transmission Range Sensor".
Check >>> here <<<. On that www page, links to PDF's, the first link describes the TR Sensor. Page 6-9 of 9 shows the removal / adjustments.
-Steven
1996 Town Car, Cartier
Old 07-27-2006, 02:28 PM
thanks for the reply town car unfortunately thats not whats wrong, i need to remove the shift linkage on the trany. It's a peice of metal about 3 inches long that looks like it bolts inside the trany. It's the metal peice the trany cable moves to select the gears. If only I need the technical name for it
Old 07-27-2006, 05:05 PM
Towncar's Avatar
Yeah, now I see what you're talking about. It's called "the Manual Control Lever"
You have to drop the Pan, the nut that holds it in; is inside the Trannie.
-Steven
Old 07-27-2006, 05:29 PM
thank town car i just figured it out right before i seen this.. thanks tho
Old 08-07-2006, 09:42 AM
BMW320i's Avatar
BMW320i BMW320i is offline
Send a message via MSN to BMW320i
Did you get this to work the 91 should be a AOD and the 93 should be a AODE. In 92 the TC's switched to AOD(E) means electric. Just curious.
Old 08-13-2006, 11:07 PM
don't have the engine running to verify if it works or not but all the electrical connections were the same
