Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-27-2006, 11:45 AM
Killa's Avatar
Killa Killa is offline
Its ok ? ( wheel fitting )
Yesterday I change my tranny fluid, so I take my passenger wheel off, I saw the tire so worm out that I can fell the metal, any way today I take my 94 wheel off ( it have about 98% tread left, I still cant believe I pay $50 for that car, havent give me problem yet ). the stock wheel on my talon is 16, and the wheel I take off 94 eclipse is 15.6/2, I swap them, and it just fine, I just want to know, that is ok to put 15 on awd talon ?
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 07-27-2006, 02:58 PM
4g63gst20 4g63gst20 is offline
Send a message via MSN to 4g63gst20
Re: Its ok ? ( wheel fitting )
NOOOOOO, you will blow your differential. at least thats what i heard.
-MODS-
Autometer Boost,Oil Presure,And Water Temperature Gauges./Geddy Turbo Tmer/Eibach Sportline Springs Matched With Adjustable Iluminas 4 Corners/Konig 18" On Nitto Extreme 555/ACT 2100 PP with Street Disc/Extended Push Rod/Urethane Motor Mounts/XS Power FMIC. 28X10.5X3.5/Greedy Type RS BOV/ evo3 16g Turbo/MBC At 18PSI/Bian Crower 272 cams/SAFC2 With 510cc Injectors/Walbro 190 FP/
1/4 mile=14.3@103MPH
Old 07-27-2006, 03:18 PM
Killa's Avatar
why ? because I put a smaller side wheel ?
GM FOR LIFE !!
95 camaro lt1
Old 07-27-2006, 03:37 PM
yes, because your differential will act like if you are turnin all the time, will be working all the time.if i was you, i would not do it for too long, maybe a few days, untill you get the right tire.
-MODS-
Old 07-27-2006, 04:56 PM
Killa's Avatar
Dam that suck ass, Im saving up money for new wheel and tire, so I put any thing below stock wheel size, will damage diff right ?,
GM FOR LIFE !!
95 camaro lt1
Old 07-27-2006, 05:09 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
if you put all 4 wheels from the 94 on you will be fine. you just cant run different size tires on a awd car
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 07-27-2006, 05:11 PM
xavier3jr's Avatar
xavier3jr xavier3jr is offline
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
no its not going to hurt anything you wheel size has nothing to do with your differential thats like saying its gana mess it up puting bigger wheels on it. your just fine dont worrie about it.
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
Old 07-27-2006, 05:33 PM
Killa's Avatar
Yea I put all 4 wheel from eclipse, to my awd talon.
GM FOR LIFE !!
95 camaro lt1
Old 07-27-2006, 06:39 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Then you'll be fine.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 07-27-2006, 07:23 PM
Killa's Avatar
phew.. that some relive feelin. My front tire have about 90% tread left, and rear is about 80%, is that ok ?
GM FOR LIFE !!
95 camaro lt1
Old 07-27-2006, 10:08 PM
Thor06's Avatar
Jizzed In My Pants
Yeah, tread thickness wont matter enough to screw up the differential.
Old 07-28-2006, 01:10 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Are the tires all worn together, or all differently? You might want to get an alignment while you're still running good tires.
95 Talon TSI AWD
97 Eclipse GST
Old 07-28-2006, 01:47 PM
Killa's Avatar
2 in the front worn out the same, and 2 in the back worn out the same. There a guy that I use to know, he doing old style alignment, and it work perfect, then the laser alignment, he he not work any more, I really dont trush any other place.
GM FOR LIFE !!
95 camaro lt1
Old 07-28-2006, 06:18 PM
What I meant was are like 3 tires wearing normal and then one of them is almost bare on one of the edges, like it's not running straight? Probalby a good idea to get an alignment anyways.
95 Talon TSI AWD
97 Eclipse GST
