Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 07-27-2006, 10:09 AM
Bodack Bodack is offline
Send a message via AIM to Bodack
14b to 13g swap
Ok guys. I've been away for a while, but like everybody I've come back in need of some help. I recently swapped in a new manifold on my car and found some pretty gigantic cracks inside my turbo. So now I'm faced with a decision. I have a nice 13g sitting around that I could use, or I could buy a new turbo because I am getting boost leak and I believe the turbo is the culprit. I found the flow rate for both at 15psi to be 360 and 405 cfm. I have yet to find whether or not it will reach 300HP, so that is what I'm looking for. Will the 13g hold up to 300HP or will I need to buy a new turbo? Also, the turbo's been sitting for a while. What cleaning steps should I take before installing it? Thanks.
1993 Honda CBR900RR
1990 Talon TSi AWD - Sold
1990 Laser RS turbo - Sold
1993 Eclipse GS - Sold
Old 07-27-2006, 12:47 PM
boyertownMidnight's Avatar
boyertownMidnight boyertownMidnight is offline
Send a message via ICQ to boyertownMidnight Send a message via AIM to boyertownMidnight Send a message via Yahoo to boyertownMidnight
Re: 14b to 13g swap
i wouldnt go from a 14b to a 13g i would think that would be a powerloss and i never seen a 13g over 250hp. You can find cheap 14b's that work great! save up a little and get a 16g off of e-bay for pretty cheap.
Old 07-28-2006, 12:26 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: 14b to 13g swap
They also have different postions of the turbine inlet, and really aren't easily interchangeable IIRC. AT any rate, the 14b maxes out at 300 whp, the 13g definitely won't get there. I got my 14b that put me into the 12s for 125 bucks. It had like 125k on it, and I put another 50k on it. Just try to buy local so you can check out the shaft play and such. If your current turbo is ok other than the cracks, you can get used turbine housings for 20-40 bucks for 6cm and 7cm, repsectively. Keep in mind that all mitsu 6 and 7cm turbine housings on 5H wheels will crack. There are 3 cracks that are typical. They only hurt performance if they keep the WG flapper from closing all the way or sealing well. And even then it just hurts spool up usually, not total power (until the housing shifts and the WGF can't close at all).
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-28-2006, 10:30 AM
Re: 14b to 13g swap
Thanks for the info. Really the only reason I was wanting to swap it was because of this dang boost leak. I built a tester and the leak sounded as if it was coming from the manifold/turbo area. Like on top of the manifold right near the engine. The manifold was cracked to hell, so I swapped it and used a 4-layer gasket but the problem still exists. But it only happenssometimes when I near 5500RPMs. I'll probably just see if I can go ahead and swap to a 16g since I know I'll want to get one eventually anyways.
1993 Honda CBR900RR
Old 07-28-2006, 12:14 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: 14b to 13g swap
Sounds like an exhaust leak. Are you sure the flange on the manifold is even, mine was warped and I had the same problem
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 07-28-2006, 11:42 PM
Re: 14b to 13g swap
You're probably fuggen right. (Please don't flame me) But the old manifold already had some broken studs, so I got new ones and a stud remover, but two of the studs were actually broken off down in the block, and I didn't think to get a screw extractor, so I just LEFT them there thinking they'd be fine. I guess I should fix those...
1993 Honda CBR900RR
Old 07-29-2006, 03:22 AM
TeamRedLine23's Avatar
TeamRedLine23 TeamRedLine23 is offline
Send a message via AIM to TeamRedLine23
Re: 14b to 13g swap
I just bought a 14b turbo for my 2g gs-t. i need to get a istall kit for but i dont want to spend $200 for it. i found some on ebay for cheap. what do you think?
http://cgi.ebay.com/ebaymotors/Mitsu...spagenameZWDVW
1997 Eclipse GS-T
Performance modification:-evo3 16g-K&N Intake-HKS SSQV b.o.v vented-2.5'' Dejon tool blow thru upper and lower-Dejon large smic-GM MAF-MAF Translator-HKS 3" Carbon Fiber Titanium TBE-stock fuel rail-Walbro 190 fuel pump-PE 650cc injectors-Accel Thundersport wires-NGK series 7 spark plugs-1g intake mani/head-
Interior Modification:-Autometer Boost Gauge
http://www.cardomain.com/id/xTeamRedLine23x
Old 07-29-2006, 10:22 AM
Re: 14b to 13g swap
First off, are you hijacking my thread? And second, don't buy anything from SS Autochrome. It's dirt cheap for a reason.You'll find many a thread on these guys.
1993 Honda CBR900RR
Old 07-29-2006, 01:13 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: 14b to 13g swap
I'd do it. Its just a friggin J pipe and some other shit. I would definately go for it.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 07-29-2006, 06:04 PM
blk_srt's Avatar
Re: 14b to 13g swap
Mods:
Old 07-29-2006, 06:53 PM
AbsoluteGTR's Avatar
AbsoluteGTR AbsoluteGTR is offline
Send a message via AIM to AbsoluteGTR Send a message via MSN to AbsoluteGTR
Re: 14b to 13g swap
So hold up, an exhaust leak will affect performance? My talon is SO incredibly slow, that it probably isnt even legal to drive. Also can exhaust air leak out through the 4 bolts that are right on top of the exhaust manifold?...because i only have three...
Old 07-29-2006, 10:08 PM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Re: 14b to 13g swap
If your exhaust leak is right before the turbo where the manifold bolts on...I would think that affects performance quite a bit because your exhaust is what helps to spool your turbo...if you arent getting as much air flow through there it wont spin the turbine as fast so you wont get as much boost or it will spool later...I dont know how much an exhaust leak would affect you after the turbo though...
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 07-29-2006, 10:48 PM
Re: 14b to 13g swap
Alright well i found out today that exhaust air does leak out through the stud that has no nut on it....
What kind of nut will suffice fo rthis missing part?
Old 07-30-2006, 12:07 AM
Thor06's Avatar
Jizzed In My Pants
Re: 14b to 13g swap
your exhaust is what makes your turbo spool
There I fixed that for you. I would just go to the hardware store and get a hardened bolt to replace it with. IIRC, its a 8mm x 1.25 bolt.
Old 07-30-2006, 11:19 AM
Re: 14b to 13g swap
Slow Boy carries those bolts and washers and I believe DSMParts.com does too if you want the "specialized" bolts.
1993 Honda CBR900RR
