Go Back   Automotive Forums Car Chat > Racing > Street Racing
Old 08-14-2002, 10:23 PM
TatII TatII is offline
engine burning oil
my engine is burning oil. when my friend drove it really hard. it smelled liek burnt oil and after every oil change only after like 50 miles. my oil gets black. is this hurting my performance?
303whp stock internal KA-T
94 Acura NSX
Best E.T. 13.559
Best Trap speed 107.62 mph
Old 08-15-2002, 12:00 AM
MadZ's Avatar
MadZ MadZ is offline
I had a similar problem a few oil changes ago, came to find out the filter wasn't screwed on tight enough and there was oil leaking out around the filter.
I haven't had the problem since. but there is really no telling what problem you might be having, you might need some new piston rings.
or a complete rebuild for that matter.
'95 Z28 conv. t-56, K&N fipk, airfoil, TB bypass, LT4 KM, flowmaster, CAGS
I can picture in my mind a world without war, a world without hate. And I can picture us attacking that world, because they'd never expect it.-- Deep Thoughts by Jack Handy
Old 08-15-2002, 12:19 AM
well its not from the oil filter i can tell you that cuase i change my oil every 2000 miles and i make sure its tight. however i do see smoke coming out of the engine bay and the wheel well. but i dont' see any smoke coming out of my tail pipes. it could be anything. but i just want know if that really hurts my performance?
94 Acura NSX
Best E.T. 13.559
Old 08-15-2002, 12:29 AM
MadZ's Avatar
check your valve cover gaskets, they may be leaking oil onto your exhaust manifold or something which would cause the smell. when you checked your oil, was it low as well, or just dirty?
Old 08-15-2002, 12:35 AM
street_racer_00's Avatar
street_racer_00 street_racer_00 is offline
It will hurt your performance when your engine blows completely to hell because it doesn't have any oil left in it......
2000 Nissan Maxima SE, autotragic, sterling mist
My Max: Getting smoked by boosted cars since 2004
2004 AF award winner: longest time period w/o posting an actual street racing story
Originally Posted by CassiesMan
I got to see boobiues!
Old 08-15-2002, 06:57 AM
TerminalVelocity's Avatar
TerminalVelocity TerminalVelocity is offline
Send a message via AIM to TerminalVelocity
check your exaust maniold, your valve cover(s) the seals around your intake manifold, also, is there water in the oil? Or oil in the water in the radiator? Do you spill when you do your oil change?
My new RHD project!
Solid Crew (Circa 2002)
Old 08-15-2002, 09:42 AM
radiator is clean. my oil level barely drops if not droped at all after 3000 miles. however i do have a leak in my valve cover gasket. but its not a big leak.
94 Acura NSX
Best E.T. 13.559
Old 08-15-2002, 10:13 AM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
You will see blue smoke out of the exhaust if your engine was burning oil. It has to be leaking out somewhere and getting on the engine.
Old 08-15-2002, 09:48 PM
sooo you figured its a external leak. but then why does my oil turn black sooo fast?
94 Acura NSX
Best E.T. 13.559
Old 08-15-2002, 11:13 PM
to TatII
What kind of motor is an S14? Is it a japanese-spec motor or what?
Old 08-15-2002, 11:33 PM
its the torquey but slow as hell reving KA24DE.
94 Acura NSX
Best E.T. 13.559
Old 08-15-2002, 11:44 PM
ever thought about doing an SR-20B motor swap? I don't know where you live, but there are plenty of places in southern Cali that can do that swap.:smoker2:
Old 08-16-2002, 12:04 AM
that swap is on my todo list. i live in nyc. there are a few places in the east coast that can do the swap too. but they're pretty far away as well.
94 Acura NSX
Best E.T. 13.559
Old 08-16-2002, 12:05 AM
Polygon's Avatar
The Red Baron
Yeah, that is a good question. Could it be a blown head gasket? I'll ask around.
Old 08-16-2002, 12:59 AM
ales's Avatar
ales ales is offline
Forza Schumacher
May I suggest a compression test and possibly an oil analysis?
Good luck
Engine burning oil jakeck Sierra 3 05-11-2010 01:31 AM
Engine burning oil eagleesi1953 Engine, Transmission and Drivetrain 3 10-06-2009 06:20 PM
Burning oil at idle bhw33191 Caprice 20 09-13-2009 01:43 PM
engine burning oil bad bubba16430 Aspire 7 05-18-2005 08:53 AM
engine burning oil savvick Engine, Transmission and Drivetrain 2 12-19-2004 05:47 PM
