Old 07-26-2006, 11:04 PM
mustardstain mustardstain is offline
Fuel Pump?
I tried to start my jeep tonight and it won't turn over. I checked the fuses for the fuel pump because I don't hear it starting when I turn the key on. THe fuse is o.k. I was wondering what the next step would be? Do I buy a new pump or is there something else I should look at first? Thanks for all the help.
99 Jeep Cherokee Sport
Old 07-26-2006, 11:12 PM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
Re: Fuel Pump?
1. Don't buy a fuel pump yet
2. The fuel pump is inside of the fuel tank
3. You will need to drain all of the fuel to lower it
4. The problem is probably not there
Recomend checking the the CPS or crank position sensor first, it controls the fuel pump.
UH.. did U say it won't turn over??? check out the battery then...
Old 07-26-2006, 11:16 PM
Re: Fuel Pump?
where is the CPS and how do I check it?? YEah the battery is ok, I have power to everything. Thanks
Old 07-29-2006, 02:44 PM
Re: Fuel Pump?
Well just letting everyone know that I took it in and found out it was an electrical module problem. From the dealer the part is going to be around 600 dollars. Thanks anyway
Old 08-06-2006, 10:46 AM
AlohaBra's Avatar
Re: Fuel Pump?
Did that fix it?
Old 08-06-2006, 11:33 AM
Ray H Ray H is offline
Re: Fuel Pump?
Originally Posted by AlohaBra
Did that fix it?
Hmmm, not sure what an electrical module is but I would think the only things that would keep it from turning over would be battery, starter, solenoid, ground or associated wiring.
