Old 07-26-2006, 08:45 PM
Avoitus's Avatar
Avoitus Avoitus is offline
Smile What is the difference between LSD Ratios?
Hi.
I would like to know what LSD ratios mean like 3.91 and 4.10
What does it and if it affects the top speed of the car. I have a 2001 BMW 330ci and I was told to change the differential to increase the top speed of my car. So can someone please answer my question. Thanks!
Old 07-26-2006, 09:05 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: What is the difference between LSD Ratios?
This is not the LSD ratio, its the final drive ratio. LSD stands for limited slip differential. 3.91 or 4.10 is how many times the driveshaft rotates in order for the wheel to make one complete revolution. A 4.10 gear will rotate faster, thus giving better acceleration but sacrifices top end speed compared to a lower gear ratio like a 3.91.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 07-26-2006, 10:12 PM
UncleBob UncleBob is offline
AF -Advisor
the math is quite simple, find the percentage difference between your current ratio and the potentially new rear end. Once you know that percentage, multiply the speed at any given gear/RPM by that percentage, and that would be your speed with the new rear end.
For example, 3.91/4.10 = 95.4%. If you are doing 3000 RPM's at 80mph with a 3.91 ratio, at the same RPM with the 4.10, your speed would be 80 X 95.4% = 76.3 mph, a difference of 3.7 mph.
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 07-30-2006, 03:03 PM
beef_bourito's Avatar
beef_bourito beef_bourito is offline
another thing is that you sacrifice some gas mileage with the higher gearing because your engine will rev higher to go the same speed.
Mr. T doesn't pity anyone who likes the Black Eyed Peas. He just kills them.
Mr. T speaks only when necessary. His main form of communication is folding his arms and slowly shaking his head. And regardless of the situation, he is always understood.
On the A-team, Face , Haniabal, and Murdoch were all masters of disguise. Mr T didn't have to wear a disguise. The bad guys didn't recognize him out of fear.
