Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 07-26-2006, 06:20 PM
boyertownMidnight's Avatar
boyertownMidnight boyertownMidnight is offline
Send a message via ICQ to boyertownMidnight Send a message via AIM to boyertownMidnight Send a message via Yahoo to boyertownMidnight
4g63t all the same?
everytime i go onto a site such as skunk2.com or anyother site they list cam gears and camshafts and other engine parts for the 95-99 4g63t's.... i thought all 4g63t stuff is the same is this true Or are some companys retarded and only listed it as a 2nd gen part becuase they not aware that 4g63t's are all the same?
Old 07-26-2006, 07:05 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: 4g63t all the same?
Some parts are interchangeable. The gears, for example, should be good for either engine. Other things such as flywheels arent interchangeable.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 07-26-2006, 08:05 PM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
And there is a differance between the early first gens (90-92.5) and the late second gens (92.5-94)...and a big differance between the first gen dsms and Second generations dsms....Like Thor said it just depends on the part.
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 07-27-2006, 12:50 PM
the only diff's i know between 1'g and 2g 4g63t's is the compression and pistons and rods 7bolt crank, i thought all head parts where the same such as cam gears,cams, i just know the 1g head flows a hell of alot better then the 2g heads.
Old 07-27-2006, 01:10 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
6-bolt motors also came with a balance shaft, they have different manifolds, heads, and a few other small differences.
1991 GSX 2.3 Stroker
