| Cavalier Problem Diagnosis Got a problem you can't fix? We can help. |
Blower fuse blows after 3-5 minutes
Sunfire 2.4L convertible 1998.
Blower fires just fine for 3-5 minutes after replacing fuse, then fuse blows. It's the BLO fuse under the hood. Doesn't seem like a short, I'd expect a short to cause it to blow out right away. Any idea on what to check or try? Any chance a flaky resistor could cause this? Am I correct about it likely not being a short? |
Re: Blower fuse blows after 3-5 minutes
something is probably getting hot and then shorting
Could it be the blower motor itself? Any way to test?
well maybe but find out how much they are and maybe just replace it, depens on the price though
alright well i looked up how much the motor would cost you at an autozone near you and your looking at about $42.99.
http://www.autozone.com/servlet/UiBr...%7ENONE%7C%7EB |
Try that out, if it doesnt fix the problem, bring it back and return to [ ]1....that's a square btw
well at least take it all out and see what it looks like, you could always try a junk yard, maybe $5. just for shits and grins
yeah a junk yard is always a possibility. and like cav2000 said im sure it will be cheaper there. might as well take a look.
take like a 9v battery and some wire with you, and try it out in the yard first though. it will not go very fast but fast enough to tell if it is shot or not
the worst thing is buying something from a junk yard and then going home to find out that it doesnt work
fo sho
^^ go back to the hood!!
I know these cars are prone to the resistor going bad that is located in the air flow inside the plastic duct housing down stream from the fan. This is accessible from under the dash (pass side I think) and is identified by what looks like an electrical sensor plugged into the duct. It is held in place by two screws and looks like a printed circuit board when removed. Since it is located in the air flow it has a tendency to get coroded over time. It affects the fan speeds and usually results in the loss of one or more fan speed settings. I dont know if all your fan speeds work or not but it may be a possible source of trouble. I know alot of people who had to change out this sensor because of fan speed issues. Note the fan should still be on at its lowest setting unless the climate selector switch is set to off.
Hope this helps you, if not, someone else with fan speed issues. |
i'm not too much help with this, the only thing i've replaced on teh interior (becasue it went out) was some light bulbs.
