Go Back   Automotive Forums Car Chat > Mazda > B-Series/Bravo/Bounty/Drifter
B-Series/Bravo/Bounty/Drifter Bravo is the Australian vesion, Bounty the New Zealand version and Drifter the South African version.
Old 07-26-2006, 02:50 PM
haro123 haro123 is offline
v8 in b2200
how hard would it be to put a big block mopar in a b2200
Old 07-26-2006, 08:15 PM
Kyrasis6's Avatar
Kyrasis6 Kyrasis6 is offline
Send a message via AIM to Kyrasis6
Re: v8 in b2200
lol, my dad has been wanting to do that for a long time, he has the engine and drivetrain but doesn't have a truck to put it in yet.
My answer to this stays fairly consistant, just as hard as it would be to swap any other engine in it that doesn't bolt up in any way.
You might need to modify the oil pan or make a new cross member under the engine for clearance, or you might have to modify the hood with a cowl induction piece. Other than that it is all your usual engine swap stuff, engine mounts, tranny mount, custom driveshaft, swapping the rear end if you want to go that route (The B2200 has larger axels then what my dads 78 cordoba had), beefing up the suspension, might have to cut out the inner fender wells and do some fabrication on the transmission tunnel. I know there is no way to fit my dads automatic from his 400 BB into the existing tranny tunnel without some modification.
Owner of Mazdatruckin.com
Old 07-28-2006, 11:47 AM
Re: v8 in b2200
what sort of motor mounts would i need to use and would i have to make them
Old 07-29-2006, 10:54 AM
Kyrasis6's Avatar
Re: v8 in b2200
Lots of fabrication will be required, no way to just bolt it in.
