Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 07-26-2006, 12:36 PM
angela5503 angela5503 is offline
2 problems with 01 Rodeo P0430 code & water leak
P0430 code went away for 2 weeks then came back. I cleaned the EGR but apparently that wasn't the problem. 02 sensor next? Also,theres water dripping from a small hose coming out of the firewall on passengers side.
Old 07-26-2006, 04:07 PM
Canucklehead Canucklehead is offline
Send a message via MSN to Canucklehead
Re: 2 problems with 01 Rodeo P0430 code & water leak
It's not surprising that cleaning the EGR didn't fix a catalytic converter or O2 sensor problem. You can either replace the O2 sensor or if you're not sure whether or not your cat is bad, swap the after-cat sensors and see if the code "follows" the questionable sensor.
2000 VW New Beetle TDI
2007 Honda CR-V
Old 07-26-2006, 04:46 PM
surferfletch surferfletch is offline
If the water is dripping out of a hose in the engine bay, it's normal, I think. From the A/C... Help me out if I'm wrong.
Old 07-26-2006, 05:34 PM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
Agree with both points.
Swap the o2 sensors and see if it follows.
The water is condensate from the a/c system. I usually recommend turning off the a/c about a mile from where you are going to stop but leave the fan on high and air selector on fresh. Helps dry out the coil and keeps nastyness from growing in the evaporator section and causing the 'dirty sock' smell.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
