Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 07-26-2006, 11:55 AM
oli_may oli_may is offline
Engine wont run.
Please I need help the Nissan Cefiro Im workin with is that the engine wont run.The starter is ok and when I turn the key to start then it starts,but wont run. What would be the problem is it the computer box or the sensors? And before I forget the engine warning light in the panel gauge wont light when I turn the key to on position.Please I need HELP!!!!!...Thanks...
Old 07-28-2006, 01:27 PM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: Engine wont run.
- check top left 'Favorite Links' at http://www.cardomain.com/ride/748507/1 if u can find your help...
- check for spark: extra plug, connect and ground it. u should see good spark if sensors/ECU are ok.
- do u hear injectors clic? Fuel hose stiffens as pump starts?
- test/disconnect MAF, it may hang ECU
- run self diag
Old 08-14-2006, 10:38 PM
caddyshackman caddyshackman is offline
hey check the compression, spark, timing, fuel makes sure it has all those and just go from there
