Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-26-2006, 10:47 AM
dykepepsi's Avatar
dykepepsi dykepepsi is offline
Send a message via AIM to dykepepsi Send a message via Yahoo to dykepepsi
Poor Performance/ killer Gas Consumption
Hello, I wonder if someone one here has some suggestions to help me out, I don’t trust mechanics and I do most of the work on my car.
Three months ago I bought a 96 Eclipse GS DOHC 2.0 non turbo for $1500; I thought it was a great deal because the interior was in GREAT! Shape although the driver side had been hit and the red door had been replaced with a black one, not to mention that, that side of the car still had visible frame damage, the engine looked as it had never ever been serviced and the owner didn’t even know what a spark plug looked like. All in all the test drive was incredible under the circumstances.
The first thing I did was a complete tune up, replacing the PVC valve, spark plugs (Bosch Platinum 4’s) and performance wires, air filter ,flushed the engine, Oil change, checked all hoses, checked and replaced all other fluids added Engine Restore and fuel injector additives. (had issues finding fuel filter, so skipped it for the time being) It ran great for a while.
My car is now running poorly for the past month or so, not to mention its guzzling gas like nothing else! it has no pick-up or power, When I’m stopped at a light and accelerate, it lags and sounds as if its going to burst a spark plug or something lol..and I swear I literally see the fuel gauge go down. I replaced the fuel filter two weeks ago, the old one was sooooo clogged that I thought; “that was the problem for the bad performance” but the problem persists
Today I turn the car on after a 30 mile trip and it beeps 12 times. Does anyone know if the car was throwing out a code of some kind? And perhaps give me some suggestions as to how to improve on my car’s performance/ power?
Thank you all so much.
Old 07-26-2006, 10:53 AM
Killa's Avatar
Killa Killa is offline
Re: Poor Performance/ killer Gas Consumption
Hi welcome to forum, did you do the engine compression test ? The fuel filter is under the battery, or under right rear passenger side.
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 07-26-2006, 11:07 AM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Have you replaced the O2 sensor? That could be your problem.
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 07-26-2006, 11:19 AM
dykepepsi's Avatar
Update
Update: I went out to the car to check the trouble codes using the ignition switch ON OFF ON OFF and finally ON within 5 seconds and this is what I got; 1-2-5-5 neither one of these number codes are in the book not 12 nor 55 ….the check engine light paused 3 seconds between each number, this code method only has two digits, I’m assuming that two two-digit numbers were given, I repeated this process 4 times and had the same result.
Old 07-26-2006, 11:33 AM
dykepepsi's Avatar
Nope, I havent replaced the O2 sensor, I didnt think to do so until I received a CEL on the matter..... however, I am now trying to figure out what the codes I received are and if one of them has anything to do with my O2 sensor...read the reply update on my post, Thanks.
Old 07-26-2006, 11:34 AM
dykepepsi's Avatar
Nope, I have not done an Engine Compression test but I will study the procedure and attempt it.
Old 07-26-2006, 12:09 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Autozone and like stores allow you to rent out tools from them. You can always see if they have a compression tester that you could use. It's a very simple proceedure. And infact they might be able to assist you at the actual store.
1991 GSX 2.3 Stroker
Old 07-26-2006, 12:13 PM
dykepepsi's Avatar
Great, I've borrowed tools from them before; I’ll call and ask, Thanks
Old 07-26-2006, 12:38 PM
blk_srt's Avatar
O2 sensors dont throw codes most of the time
Mods:
Old 07-26-2006, 04:12 PM
Killa's Avatar
yup, I think they throw code after they fell off. My friend honda did that, over 250k miles, same o2, until it fell off.
GM FOR LIFE !!
95 camaro lt1
Old 07-26-2006, 04:21 PM
blk_srt's Avatar
Well yeah, it will throw a code if it breaks or falls out but if you wait untill then to change it you have other problems
Mods:
Old 07-26-2006, 06:20 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
I second the o2 sensor diagnosis. It will make your car run sluggish and basicly give you the worst gas mileage possible. Replace that with one from Auto Zone (they are cheapest there from what I've experienced) and see where that gets you.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 07-26-2006, 06:32 PM
dykepepsi's Avatar
Thanks, I will definately try that. I was already reading about the replacement of the O2 sensor.
Old 07-26-2006, 07:18 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Do you NT guys have an upstream and a downstream o2 sensor? Just my own curiousity...
And dykepepsi, what the hell are those things in your avatar?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 07-26-2006, 09:21 PM
Yes
'92 3000gt SL
Zoom Stage 1 Clutch
