Old 07-26-2006, 10:26 AM
jdlgall jdlgall is offline
Vibration from Fan
When my fan turns on it sounds like a jet, it vibrates to the point that it has cracked a weld on the A/C and leaked out the freon, Can anyone tell me the solution to my problem.
Old 07-26-2006, 12:28 PM
busboy4 busboy4 is offline
Re: Vibration from Fan
Hi
Are you talking about the radiator cooling fans under the hood? I have no specifice experience with the problem you describe, but I would guess and out-of-balance problem with the fan itself, or perhaps an internal failure in the motor causing a similar balance issue. I might visually inspect the fans for anything that would obviously cause the problem: a chunk missing from a portion of the fan for instance, but in the long run I would probably look at a remove:replace of the suspected fan. By the way, if the rad fans are what we are discussing, do you know which one is at fault?
Old 07-31-2006, 01:59 PM
98er 98er is offline
I had this recently on a Thunderbird. The fan blade cracked and would expand to a larger diameter when running. It actually shook the lower rad hose from the radiator. Ford only sells the whole fan/motor/housing assembly and it's close to $300. I'd recommend a yard. I found one fo the T-Bird for $50 and is like-new.
Marc/Atlanta
