Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 07-26-2006, 10:06 AM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
PK2 Passlock 2 system failure and bypass proceedure
OK I've read the service manuals, and it sure seems doable. This should cure any problems with the antitheft kicking in and not allowing the car to start. This is also a far better way than installing a switch like so many have done on here before. Now, remember this is free advice so I'm not responsible for anything that may go wrong with you trying to do this....
You cut the RCode wire and wire a (PL2 acceptable) resistor across the the cut wire and the PL ground. A resistor that would be within the normal range for the passlock system this could be almost anything since there is a very broad range for this. When doing remote starters, I've seen these be anywhere from 1,000 to 56,000 ohms. Now this proceedure is how to replace and program a new cyl. lock yourselves without having to go to the dealer for them to "unlock" the system.
1. Attempt to start car; it will crank and fail, with the security light flashing. Leave the ignition on for 10 minutes, until the security light goes out.
2. Repeat step 1, two more times.
3. Car should now have learned its new key cylinder, or in this case, new resistor.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
