Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 07-26-2006, 12:27 AM
chaney3000's Avatar
chaney3000 chaney3000 is offline
Question Cold air intake
Does anyone know of a adapter for a 91 Caprice that allows you to install a cold air intake? The throttle body is vertical not horizontal like those on the 94 & up, so the kits won't fit the throttle body. Does any one have any suggestions?
Old 07-26-2006, 12:46 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Cold air intake
1991-93 Cadillac Fleetwood w/ 5.0 or 5.7 liter engine
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 07-26-2006, 08:11 AM
kdrolt kdrolt is offline
Re: Cold air intake
Yes. Read:
http://impalassforum.com/cgi-bin/ult...c;f=9;t=001945
Old 07-26-2006, 06:45 PM
chaney3000's Avatar
Re: Cold air intake
The fourth picture is how my set up looks without the mods. I want to install a cold air intake on a caprice that has the intake system like that. The other pictures are nice but they are showing a different setup with different model cars.
Old 07-26-2006, 07:12 PM
capriceowns capriceowns is offline
Re: Cold air intake
there all TBI, just like yours. Just some have different style boxes over the TBI unit. They probably made them.
Old 07-27-2006, 12:13 PM
Re: Cold air intake
capriceowns is correct --- all the cars shown ij that thread are 91-93 models using throttle body fuel injection ---- JUST LIKE YOURS. The pix are all *after* the modifications have been made.
Most of them start with the plastic airhat from a late 80s early 90s fwd Cadillac v8 (get one from a junkyard, along with the bent threaded rod + knob), because it conveniently fits atop our TBI units and provides a way to attach a long sewerpipe, from which a cone filter can be used. In that sense it mimics many of the DIY CAIs used on 94-96 LT1 cars like the Impala SS.
The other ones, that don't use the Caddy airhat or the truck-style Airaid equivalent of it, start with the stock GM plastic airbox and than add a second cold air feed to the passenger side, which makes it breathe better and still look like a factory part. They also usually drill more holes in the metal silencer ring that also acts as a support for the back half of the plastic filter box.
There's a bit more info here by scrolling approx 3/4 of the way into this post:
http://impalassforum.com/noncgi/ulti...;f=33;t=009021
HTH.
