Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 07-25-2006, 11:12 PM
AbsoluteGTR's Avatar
AbsoluteGTR AbsoluteGTR is offline
Send a message via AIM to AbsoluteGTR Send a message via MSN to AbsoluteGTR
Syncromesh vs Syncroshift
My talon has a very hard time shifting into 1st, 2nd and reverse. Its not hard literally...it just likes to grind. So I am going to change the tranny fluid, hoping this will cure the problem. Also, i will probably change the transfer and differential fluids as well. So my question is what type of fluid should I use?
I have read alot about Pennzoil syncromesh and GM syncroshift (or however it goes). but I also read on tuners that one of them is NOT GL4 and is not good for the tranny. Anyways, what do you guys think is the best fluid to buy for the tranny, transfer and diff.
Also is this right.....? The tranny and transfer take GL4 and the diff takes GL5?
Also how much of each do I need? (3 quarts of GL4 and 1 quart of GL5, correct?)
And one last question...How is the product Redline?
Old 07-25-2006, 11:19 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: Syncromesh vs Syncroshift
Redline shockproof is the best thing for in your transfer case and rear diff.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 07-25-2006, 11:36 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Synchroshift and Synchromesh (I'm 95% sure it's those two) are almost identical fluids and are manufactured by the same companies and just bottled in different bottles. Either one will be "fine" but like blackcrow said, Shockproof would be your best bet. Look back a couple months, there was a big 4 or so page discussion on what is the best stuff for our cars.
95 Talon TSI AWD
97 Eclipse GST
Old 07-25-2006, 11:48 PM
So the exact same bottle will work for both the transfer and diff? I thought they needed two different types of fluids.
Also, should i use redline schockproof for the tranny fluid?
Also what weight oil do I use?
Thanks
Old 07-25-2006, 11:51 PM
http://www.automotiveforums.com/vbul...ht=synchromesh
Read the 3rd post.
95 Talon TSI AWD
97 Eclipse GST
Old 07-25-2006, 11:58 PM
Or just read all of my posts in it. lol
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 07-26-2006, 08:07 AM
Killa's Avatar
Killa Killa is offline
Any one here right now, running pennzoil with heavy shockproof for tranny ?. Im running stray pennzoil right now, and might want to mix 1 quart of shockproof and 1.5q pennzoil.
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 07-26-2006, 09:30 AM
Well i guess Pennzoil syncromesh in the tranny, and redline shockproof in the transfer and diff. it is.
I run this stuff straight right? Because Killer mentioned something about mixing some and some...or is that just for his application?
Old 07-26-2006, 09:34 AM
Killa's Avatar
I been read about this year ago, when I first have my manual car, people actually mix those 2 together, kevin been mix them too, I just run stray pennzoil, but now I might mix those 2 together, let see what up.
GM FOR LIFE !!
95 camaro lt1
Old 07-26-2006, 12:41 PM
Killa's Avatar
I just change my tranny fluid 1 hours ago, 1 quart of shock proof and the rest is pennzoil, I think run stray peinnzoil is too thin. Cause when I drain it , I saw it too thin.
GM FOR LIFE !!
95 camaro lt1
Old 07-27-2006, 05:42 PM
Howd does the car run and shift now? Thinking about maybe mixing the fluids in for my tranny. Dont want it to be to thin...
Off subject question? My engine was rebuilt with all new OEM pistons, rings, etc. What kind of oil should I run? I changed it about 1 week ago and it is starting to leak, not burn, oil. I am running 5w30 right now...is that too thin?
Old 07-27-2006, 05:44 PM
Killa's Avatar
The car shift kinda the same as before, mabe a little better. Any way where does the oil leak from, our dsm should run 10w/30, I run 10w/30 castrol gtx( I cant run syntec cause I scare leak, 146k mile.)
GM FOR LIFE !!
95 camaro lt1
Old 07-27-2006, 08:26 PM
GTR, you can run Synthetic if you want, otherwise just stick with 10w30 (but I still recommend synthetic). I like to run Mobil 1 10w30 when I use synthetic. And you should probably fix that oil leak.
95 Talon TSI AWD
97 Eclipse GST
Old 07-27-2006, 10:41 PM
george536's Avatar
george536 george536 is offline
i put water in it all day, WOOOOOT im d runkg
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 07-29-2006, 10:36 PM
Thats what I am running right now (Castrol GTX 10w30)...I dont know why in hell I said 5w30...that was wierd
Also what would be the advantage to running synthetic?
