Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 07-25-2006, 10:19 PM
screaminmiata screaminmiata is offline
96 civic passenger power window wont go down
My 96 civic passenger window wont go down. Replaced motor and switch, when the switch is plugged in the window regulator goes up but wont go down. Dont even have to push the button as soon as its plugged in it goes up., wont go down. switched back door switch with the front, and the front does the same but the front switch moved to the back works fine. I am wondering if there is a wiring problem. Main switch wont work the passenger window. All other windows work fine. I took the motor and regulator out hooked up to battery charger and goes up and down. I'm lost any ideas?
Old 04-07-2007, 06:03 PM
MarVar MarVar is offline
Re: 96 civic passenger power window wont go down
[MarVar Wrote] I'm having the same problem, have you found a solution? I used my old regulator test things and I've switch the wires and the regulator will go up but not down. Also, the drivers door will not work at all in any case. Looking forward to your response.
