Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-25-2006, 08:58 PM
monsta2001 monsta2001 is offline
Send a message via Yahoo to monsta2001
Cranking no Starting
Here it goes. I was driving home from work in my 97 eclipse spyder 2.4 and the car just died. So i looked into it and my balance shaft belt broke, but in the process it broke my crank position sensor in two. So i replaced the belt, the sensor,and tried to start it up and nothing. Its cranking over but not starting. Im getting fuel and spark, and i also replaced the cam sensor and still nothing.If anyone could help point me in the right direction i would greatly appreciate it. I miss driving my car dearly. ow ya it seem like its cranking funny like its whinning.
Thanks.
Old 07-25-2006, 10:35 PM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
Re: Cranking no Starting
you will be locked and no one will help you, but try plugging in the crank sensor... then put a new timingbelt on cause you prolly fucked that up too
Old 07-25-2006, 11:23 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
This belongs in Problem Diagnosis, next time use the correct sub-forum please. Run a compression test and let us know what you get for numbers, I'm willing to bet you jumped timing and bent some valves.
Oh yeah, and welcome to AF.
95 Talon TSI AWD
97 Eclipse GST
Old 07-26-2006, 02:09 AM
thanx ill run test tomorrow.Appreciate it.
