Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 07-25-2006, 07:26 PM
El Bucho El Bucho is offline
'92 98 Tie Rod Ends
So the state inspection guy says I need new tie rod ends to pass, but I say he's full of poo because the wheel barely moves. There is a slight "Clicking" sound when you try to wiggle the wheel, but it is definitely within limits. Anyway, I replaced the outer tie rod end with no problem, but need some help replacing the inner one. Anybody have any directions on how to get in there and change that thing? Thanks in advance.
EB
Old 10-18-2006, 10:06 PM
89oldsregancy 89oldsregancy is offline
Re: '92 98 Tie Rod Ends
i just did an inner tie rod on my olds if you have the right tools its easy, keep in mind you will need and alignment when your done. remove the outer tie rod then the boot located right by the steering rack and theres you inner tie rod basicly comes off with the same idea as the outer tie rod you just need a tool to get at it and spin it
