Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 07-25-2006, 04:11 PM
capriceowns capriceowns is offline
Scanning tools?
I really need a scanning tool, and the one that can hook up to my carb as well.
What are the names of them? Ive never used them before so idk what there called.
What it cost me to buy the two I need?
Old 07-25-2006, 05:57 PM
Blue Bowtie's Avatar
Registered Offender
Re: Scanning tools?
What year(s) vehicle are you asking about?
Old 07-25-2006, 11:35 PM
Re: Scanning tools?
for my 87 caprice.
I just need a cheap o one that shows the code errors, and can maybe plug into my carb.
Old 07-26-2006, 06:07 PM
HLandin's Avatar
HLandin HLandin is offline
Re: Scanning tools?
Your 1987 car will use OBD I which means you can find a wide variety of cheap scanners. The one I use will cause the service engine soon light to flash to display the code when plugged in. As a alternative, you can use the jumper method to flash the codes (just get your terminals right).
Old 07-26-2006, 06:13 PM
Re: Scanning tools?
Ive never heard of a jumper method, what is it?
Old 07-26-2006, 06:43 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Scanning tools?
Use a paper clip, a wire or whatever to jumper the A & B terminals of the ALDL (under the dash to the left of the steering column, plastic plug that says "DIAGNOSTIC") and turn the key to Run but DO NOT START the engine. It will flash a series of flashes - i.e. flash-pause-flash-flash indicates a 12, flash-flash-flash-flash-pause-flash-flash-flash-flash-flash indicates 45 etc. The trouble codes flash 3 times each before moving onto the next.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 07-26-2006, 07:11 PM
Re: Scanning tools?
sounds easy enough thanks. Will it display any codes my carb is throwing out, or just the engine?
Old 07-26-2006, 07:14 PM
silicon212's Avatar
Confoundingly Lucid
Re: Scanning tools?
The carb does not throw out codes - that's dealt with by the ECM. The ECM will display carb related codes however, such as lean, rich, M/C solenoid, etc.
Old 09-15-2006, 05:18 AM
WMX267 WMX267 is offline
Re: Scanning tools?
i'm sorry to butt in... but a scan tool only serves the purpose of being able to tell you if all our sensors work well right? But to be able to do make changes on the way your engine performs (that's called tuning?), you would need a different tool or program? is that what they call flash reprogramming? what products are available in the market... I drive a honda 2000 civic, but i'd also want one that would be compatible with other vehicles as well. any additional information about scan tools, OBD's and tuning would be appreciated. Thanks a lot!
Old 09-15-2006, 12:50 PM
Re: Scanning tools?
You got too much Honda on your brain confusing you.
A scanner just doesnt display Sensor codes. it does, but with todays engines, a sensor can tell you everything about you car. the sensor will tell you if its broken or if what it was designed to read isnt right.
as for "tuning" i dont know if you mean ricing but you cant really tune your car, its all handled by the computer.you can change like idle and stuff. but thats it. you can reprogram it, but thats too much work.
all scanners for your car which is OBDII are the same theyll all display the codes, just some are more fancy that tell you what the codes mean/have other tests.
1987 Chevrolet Caprice classic Brougham. 142,000 on the 305 and still chugging
Old 09-15-2006, 02:15 PM
silicon212's Avatar
Confoundingly Lucid
Re: Scanning tools?
To expand on this, OBDII has certain codes that are the same across manufacturers, but there are manufacturer-specific codes also that vary from car to car. The OBDII system pretty much tells you exactly what's wrong with the car.
Old 09-16-2006, 07:17 AM
Re: Scanning tools?
[quote=capriceowns]You got too much Honda on your brain confusing you.
I believe reprogramming is what i am referring to when i wrote "tuning". and yes... i do mean the one's that are used for racing (ricing?). won't you able to adjust the amount of fuel delivery, ignition timing, airflow (somewhat like airflow controllers), etc. using that reprogramming tool on a computer? what's it called by the way? - and is that still different from a scan tool? isn't that the gadget they had on Fast and the Furious?
oh yeah... OBDII tells us exactly what is wrong with the engine because it has a predetermined set of trouble codes for specific problems right? the need for a scan tool, is really to be able to convert the bleeps of the check engine light into readable material. right?
Old 09-16-2006, 12:41 PM
Re: Scanning tools?
[quote=WMX267]
exactly
Old 09-20-2006, 06:25 AM
Re: Scanning tools?
okay.... so what do they do exactly when they "tune" a car? as in racing. what's a dyno?
Old 09-20-2006, 01:47 PM
Re: Scanning tools?
when they tune a car they usually dyno it, look at spark advancement, and fuel/air mixture and adjust occadridanly to what they need it for what ever there doing.
