Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 07-25-2006, 10:42 AM
Bannon7414 Bannon7414 is offline
Send a message via AIM to Bannon7414
No Temperature
I'm not getting a temperature reading on my gauge for my coolant. Why could this be? I just had a full extensive tune up with new ignition coil and module.
1994 Chevy Caprice 350 5.7L Police Package
Old 07-25-2006, 11:39 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: No Temperature
Did you check the sending unit to ensure the wire is still on it? Sounds like it could have been knocked off. The sending unit is on the cylinder head between either the #1 and #3 spark plug, or between the #6 & #8 spark plug.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 07-25-2006, 01:14 PM
Blue Bowtie's Avatar
Registered Offender
Re: No Temperature
In addition to the good advice Si offered, you can ground the green wire from this sending unit anywhere on the engine. Turn the ignition switch to RUN and observe the temperature gauge - It should sweep to the full HOT position or slightly beyond. If not, there may be a wiring, instrument, or GAGE fuse problem. If the gauge does sweep full hot with the wire gounded, but still doesn't work with the wire connected to the sending unit, test the resistance of the sending unit connector to ground and compare it to the table:
Old 07-01-2007, 01:35 PM
Don-D Don-D is offline
Re: No Temperature
What Kind Of Tool Is Used To Test The Resistance? And What Does That Tell You?
