Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 07-25-2006, 10:05 AM
lsj102856 lsj102856 is offline
94 bonneville
I can drive my car somewhere and turn it off and then it won't restart you have to wait 20 or 30 min. and it will start like new or if you start it and the check engine light comes on, turn it off for 30sec. and restart it and the engine light will not come back on. I have replaced the fuel pump and the ignition module any ideas why it won't restart for 30 min?
Old 07-25-2006, 06:33 PM
jdq jdq is offline
Re: 94 bonneville
need codes,but posible cam or crank sensor
2000 bonn ssei 155000 klm
1997 dodge caravan 92000 klm
Old 07-25-2006, 07:22 PM
maxwedge maxwedge is offline
A990 racer
Lightbulb Re: 94 bonneville
Welcome to AF, as a result of not doing any diagnostics you seem to have spent some money here. Try dumping some water on the crank sensor which is mounted on the r/s of the crank balancer. Or check for spark and injector pulse when this occurs( recommended method) if none either the cps is bad or the wiring from the cps to the icm.
Old 08-15-2006, 11:06 PM
19Bonneville94SSE 19Bonneville94SSE is offline
Send a message via AIM to 19Bonneville94SSE Send a message via Yahoo to 19Bonneville94SSE
Re: 94 bonneville
Its most likely the crank sensor, when it went bad on my car the water never worked but it was tripping the check engine (SES) light . The sensor is in the harmonic balancer
