Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-25-2006, 09:49 AM
dwaynem3's Avatar
dwaynem3 dwaynem3 is offline
Exclamation 1994 talon tranny problems
replace engine and tranny out of a car that was upside down engine works great but tranny not shifting right ?is it the sensors?could it be dirt from being upside down ? where should i start? thanksok sorry guys It's an automatic when i first start car put it in drive it works fine 1st 2nd 3rd od when i stop and start again if i put it in drive i start in drive no 1 2 3 or od i can put it in 1st it works if i then shift manually but but no lower gears if i start in drive
Old 07-25-2006, 10:53 AM
ned032002's Avatar
ned032002 ned032002 is offline
Re: 1994 talon tranny problems
Well what do you mean by not shifting right? Is it an Auto tranny or manual tranny? Try putting your car info in your sig that way you never have to say what kind of car you have ever again. If its a manual tranny, was the clutch all nasty when you put the engine and tranny into the car?
Welcome to AF.
Old 07-25-2006, 12:06 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
I'll be blunt. Your description sucked balls. Repost with more information and maybe somebody will help you.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 07-25-2006, 12:24 PM
Killa's Avatar
Killa Killa is offline
Im guess its manual, What kind of fluid did you use, did you adjust the clutch cable ?.
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 07-28-2006, 12:47 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Sounds to me like something is fucked up inside . Have you changed the fluid and filter? Try that and see if it helps at all. You could try installing a new torque converter, but I don't think that's the base of your problem.
95 Talon TSI AWD
97 Eclipse GST
