Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-25-2006, 07:20 AM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
Alternator Belt
Mine snapped... I replaced it, I wanna make sure that I have it tensioned right... How do I do that... and if it's not tight enough, how do I get it tighter... (it doesn't have an automatic tensioner, and I saw no way to tighten it[other than hand-tight])
Old 07-25-2006, 10:30 AM
SLoe's Avatar
SLoe SLoe is offline
Re: Alternator Belt
Hey man, I don't remember what year, make, and model you have. Would you please put them in your sig? It would make things easier
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 07-25-2006, 10:40 AM
Mikelb's Avatar
Re: Alternator Belt
ok, easy enough
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 07-25-2006, 10:53 AM
SLoe's Avatar
Re: Alternator Belt
Thank you! I would have told you how to do a turbo car, since I have never owned a NT. So just guessing here, you are looking for possibly an adjuster that moves the alt so the belt gets tighter, or if you don't have that get something to pry it with (don't go crazy and break shit though). I have a belt gauge for setting tension, but if you don't have one a good rule of thumb; you should have it tight enough that you can only move it about 1/2"- 3/4" when you push on it with a reasonable amount of force. My advice to you is to go get a chiltons manual also. You are going to need it
Old 07-25-2006, 10:57 AM
Mikelb's Avatar
Re: Alternator Belt
well, there's no adjuster (that I have seen)... the alternator is held on by two bolts... one seems to be just so the alternator can swivel (doesn't tighten, allows the alternator to move closer or further from crank to adjut tension) the other is a slotted bracket... I see no way to push the alternator to a tension while tightening the bolt... if so, I woulda had no problem...
Old 07-26-2006, 06:21 PM
Blaiser17 Blaiser17 is offline
Send a message via AIM to Blaiser17
Re: Alternator Belt
it sounds as if you're missing the tensioner itself
goes in the slotted bracket
1999 Chevy Monte Carlo 3.1L
1991 Chevy Camaro 3.1L
1981 Chevy Camaro z28 383 Stroker
2000 Mercury Cougar v6
Old 07-27-2006, 07:15 AM
Mikelb's Avatar
Re: Alternator Belt
there's a bolt on the alternator in that bracket... where would the tensioner go???
Old 07-27-2006, 08:25 AM
SLoe's Avatar
Re: Alternator Belt
Does a 420a even have a tensioner? IDK. Apparently not in this case Like I said, get a chiltons. Can you not get a pry bar in there? to put tension on it while you tighten the bolt? Why don't you pm one of the NT guys? |eclipse| , gthompson, or someone!
Old 07-27-2006, 09:29 AM
Mikelb's Avatar
Re: Alternator Belt
possibly... a large prybar... but I don't see a tensioner... I'll pm Gthompson... see what he's gotta say
Old 07-28-2006, 01:05 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Alternator Belt
Still haven't gotten that PM yet!
The 420a does have a tensioner on the alternator, I believe it runs horizontally with belt right on top of the alternator itself. There is a lock nut sort of thingy that you have to loosen up that faces the frame rail, and then the actual tensioner bolt head faces the firewall. The first couple times, a trouble light helps out immensley because it's kind of a tricky bolt to find. I haven't worked on mine for awhile so I'm sorry if the explanation is sort of vague, but let me know if you have any troubles or anything. I actually have a motor pulled right now that has the alternator still on it, I'll see if I can snap a pic of it if you have trouble finding it.
95 Talon TSI AWD
97 Eclipse GST
Old 07-28-2006, 07:25 AM
Mikelb's Avatar
Re: Alternator Belt
sry haven't had much freetime, not even here at work... and too much is going on... (house, two cars, three jobs, baby on the way...need I say more)
yeah, I haven't seen the tensioner... I will look, but a pic would definitely be a help... thanks for the info though...
like I said, sry a/b not getting around to the pm... been busy
Old 07-28-2006, 08:26 AM
SLoe's Avatar
Re: Alternator Belt
Ahem......
You're welcome. :P :15millionsign:
Old 07-28-2006, 08:30 AM
Mikelb's Avatar
Re: Alternator Belt
Ahem......
y thank u
Old 07-28-2006, 04:41 PM
Re: Alternator Belt
search ebay for your alternator bracket and you'll find a pic of the tensioner there with it, it's like $5 to buy both of em together
here ya go....
http://cgi.ebay.com/ebaymotors/4G63-...QQcmdZViewItem
