Old 07-24-2006, 11:06 PM
jaifai jaifai is offline
cooling problems?
I have a 3000 Gt 95 SL and the car get hot when I'm driving on the highway in the afternoon, as soon I slow down and lower the Rpm the car goes to normal parameter. I change the thermostat and flush the radiator. In the morning when is cooler the car work fine. Can someone help me. it driving me insane. Thank you!!
Old 07-24-2006, 11:21 PM
Ralliart 3000gt's Avatar
Ralliart 3000gt Ralliart 3000gt is offline
Re: cooling problems?
I would get an auto electrician to check your electrics. Tell him you think it’s the radiator fan. Even if its going while you are parked it could stop while you start to drive. The motor on these fans brake down slowly, so you can’t tell.
Old 07-25-2006, 12:52 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
so you've already changed the thermostat. good for you, that was gonna be my first suggestion.
when it gets hot, how hot does the temperature gauge read? does it get all the way up to the red "H" ?
i'm not positive about how the radiator fans work, but i DO know that they WILL come on when you have the A/C turned on. not just the blower running, but the A/C button has to be pressed as well. this will ensure that the radiator fans are on and running. try this next time you notice the engine temp. getting hot.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 07-25-2006, 10:18 AM
2old 2old is offline
I think you have a clog somewhere... Our radiators work better when we are at speed and I actually find the temperature is lower when the car is moving...
Check for a coolant hose somewhere that is restricting the coolant flow (bulges, parts that feel softer then normal, etc.)
Old 07-25-2006, 12:25 PM
Igovert500's Avatar
blue + red light magnet
Yep, t-stat and a clog were gonna be my first two guesses.
Just to make sure your fans are working, turn the car on, and turn the AC on, I think that causes both fans to come on if memory serves me correctly.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 07-25-2006, 01:24 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Yes, it does, I would know I was trying to charge my A/C last night.
Old 07-25-2006, 03:05 PM
I change the two hoses on the radiator, I do not know but some radiator hoses have the spring on the inside so the hose wont bulge. I donot know If this car has to have those spec do you know if your car have that spring or the re-enforce hose. needs help thanks.
