Go Back   Automotive Forums Car Chat > Ford > Focus | C Max
Old 07-24-2006, 08:43 PM
SilverZTS SilverZTS is offline
Trunk Latch problem
Please help!!!
My 2002 Focus has a bad trunk latch, it clicks a lot but only opens when I pull up on the trunk. I found a used latch that works, but now I need to put my old key cylinder on the new/used latch. How do I remove the cylinder assembly and reinstall mine? I managed to remove the entire lock mechanism only to be puzzled in replacing the key cylinders.
Old 08-28-2006, 12:22 AM
ppence418 ppence418 is offline
Re: Trunk Latch problem
my trunk does the same thing have a 05 zx4, i found that if u use the inside release it works better than the keyless entry.
Old 10-15-2006, 07:33 PM
rivguy rivguy is offline
Send a message via Yahoo to rivguy
the lock cyl. is hooked to the latch by turning it inot place and a spring loaded pin prevents in from comin gback off. ford sais to cut the case of the lock cyl. just behind the spring, tap the hose and install a new plug. but, I have done a few and since you are relacing the latch anyhow you can jsut break the plastic case on the latch and use a pick to release the lock pin.
-=-=-DANE-=-=-
Old 11-01-2006, 11:28 AM
k_lev k_lev is offline
This is a recall from Ford. Take it in to your local dealer and they'll replace it at no cost to you - for once.
Old 11-01-2006, 05:53 PM
since when - I work at a ford dealer and haven't heard about a trunk latch recall. the rear door latches are recall but no trunks.
-=-=-DANE-=-=-
