Old 07-24-2006, 06:21 PM
Mr Common Man's Avatar
Mr Common Man Mr Common Man is offline
Question My Camaro HeadLights Are Constantly Going Out
I drive my 1997 v6 camaro 3800 about 87 miles a day to work and during a 4 month period i've had to change my low beam headlights 2 times one side one week then the other side about 2-3 weeks later. With me having to purchase the whole headlight assembly its very expensive, about 56 dollars a headlight. Does any have any idea what could be the problem?
Old 07-24-2006, 07:43 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: My Camaro HeadLights Are Constantly Going Out
You got a short somewhere. Either one of the wires is exposed and shorting itself out or its getting built up moisture somehow like often happens with the tail lights.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 07-24-2006, 08:24 PM
How can I find the short, do I need to trace the main wire back and does it often happen with both headlights?
Old 07-24-2006, 08:28 PM
FormulaLT1's Avatar
Fight the powwa!!!
thats semi easy. Yes the wires are all right there and if you own ramps , great. Just get under the car and trace the wires back while all checking to make sure there is no break in the wire. You can also try a volt meter to see if you can find a spike.
Old 07-24-2006, 08:31 PM
thanks, and should that not be the problem any other suggestions
Old 07-25-2006, 10:06 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Defiantely start at the grounds and work your way back, especially if it's a shared ground with say the cooling fans?
