Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 07-24-2006, 03:58 PM
jeepgclwj's Avatar
jeepgclwj jeepgclwj is offline
1993 Ranger clutch problem....
I went out this morning to start my truck and the clutch pedal went straight to the floor. My truck started fine I just couldnt get it into any gear when it was running and clutch kept hitting the floor. When I backed it up to the garage last night it ran with no problems. I looked for any fluids on the ground and nothing. I looked under the dash at the clutch pedal and I really dont know what to look for. I do know that there was never any message or sign that my clutch was going out.
Anybody have a clue at what could be wrong. I really need my truck, its good on gas.
thanks in advance
chad
358rwhp/358rwtq with stock LS1 intake
A4 3.23 lid, pacesetter lts, ory, 243 heads, SLP LMI, ZO6 cam, BBK SSI intake, 85 mm
Old 07-24-2006, 04:19 PM
KimMG KimMG is offline
AF - Advisor
Re: 1993 Ranger clutch problem....
Did you check the fluid level in the clutch master cylinder?
http://www.autozone.com/servlet/UiBr...3d800babcf.jsp
Old 07-24-2006, 08:44 PM
12Ounce 12Ounce is offline
You probably treat the fluid in your system like I treat mine ... just forget it! It could stand yearly, or so, dumping and refilling ... yeah, I know, I don't either.
Your symptoms sound like the master cylinder is getting a little flacky. I'd go ahead and buy a replacement ... and change it out when you can. I've done this job ... not as easy as a brake master cyl, as I recall, but not extremely difficult.
Old 07-25-2006, 08:44 PM
aceandy aceandy is offline
Is it some sort of mechanical linkage problem? "the clutch pedal went straight to the floor"... ?
Old 07-27-2006, 08:25 AM
dp62273 dp62273 is offline
Send a message via Yahoo to dp62273
sounds like there is air in the line
