Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 07-24-2006, 03:55 PM
tsi fan tsi fan is offline
have evo 3 16 g where next>>>
have and evo 3 16g turbo....besides a boost controller what do you think would be the next best step in performance upgrades...?
Old 07-24-2006, 04:05 PM
steviek's Avatar
steviek steviek is offline
Re: have evo 3 16 g where next>>>
well depends on what you have already.
Most people start with exhaust, Intake and BOV.
THen they improve fuel pump, injectors (and a way to control them).
But since you've skipped ahead and slapped a 16g on there (which is very dangerous) I would say your lucky you haven't fucked up your car.
This should be your new bible
http://www.dsmtuners.com/sub.php?page=2gtstage1power
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 07-24-2006, 04:09 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
tuner's guide
now - 2000 civic
soon - 2002 is300
I'm only running 8 psi (stock level) waiting to get a full setup before i turn it up
Old 07-24-2006, 04:40 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Yeah, you should be fine on stock boost (not 8 psi, its like 14 for 2g's and 10.5 for 1g's). I would personally go for a full 3" exhaust, K&N air filter, a 2g exhaust manifold/o2 sensor housing (if your car isnt a 2g already), a decent BOV (stock 1g should suffice to ~22 psi if you are cheap), a bigger fuel pump and FPR if you get a 255, then some fuel control (DSMlink if you're strapped, SAFC if you are cheap), then bigger injectors (go big if you have DSMlink, 650's max if you go SAFC), then give it a decent tune and crank the boost. IMO intakes are way too much for what they do, if you go Home Depot style for one, thats ok, but buying a metal one is rediculous. A FMIC should get in there after the fuel control.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 07-24-2006, 11:34 PM
I also have a K&N an intake pipe got it off machv.com but the stuff is a lot of $$ so yeah... on the site machv.com i could get a full 3" stianless steal exhaust (minus 02 housing and headers) for $799.00 would that be a good way to go..plus headers and o2 housing?
Old 07-24-2006, 11:40 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Apexi N-1 3" exhaust. We only have 1 manifold so you would only need ONE headeR, but just stick with a 2g exhaust manifold. Crunchy meant go to www.dsmtuners.com and click on tech guide and look up the list for your car. Also put your car and mods in your signature. Welcome to AF.
95 Talon TSI AWD
97 Eclipse GST
Old 07-25-2006, 12:02 AM
just spent the last two hours reading throw everything the guys from dsmtuner.com had to say..looks like some good stuff
MODS...
K&N
Hard intake pipe
Evo 3 Big 16G
Old 07-25-2006, 12:08 PM
TheRomer TheRomer is offline
I got a full 3 inch turbo back for $150 . I suggest buying used, no need to spend $800 for an exhuast.
Do you get any boost creep with that evo 3?
Chris Winchell
95 GSX 12.5 ET with a 1.9 60' at 115 mph
Actually have traction this year
90 TSI <Project Acer>
2.0L, 2400 lbs AWD, t-67 goodness
Old 07-25-2006, 02:11 PM
if you have boost creep you ain't runnin enough boost
now - 2000 civic
soon - 2002 is300
Old 07-25-2006, 03:48 PM
Thor06's Avatar
Jizzed In My Pants
Yeah, for used shit. I got my full 3" exhaust for $350 which isnt too bad since the catback was used all of about 3 months.
Old 07-25-2006, 05:06 PM
I don't get any boost creep spools up great... Good used>>where is the best place to buy a used exhaust>>?
Old 07-25-2006, 06:30 PM
Thor06's Avatar
Jizzed In My Pants
Locally. I dont trust eBay much anymore.
Old 07-25-2006, 07:42 PM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Try dsmtuners in the classified section or you can try dsmtrader.com
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 07-25-2006, 09:48 PM
so go used>>? what type of headers and o2 housings are the best? do you recommend going used on those too?
