Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 07-24-2006, 03:07 PM
eborn eborn is offline
Help!
ok, i have just done a motor swap in a truck. it's a 350 punched .40 over, mild cam, about 10.5:1 compression. it has a holley 600 4 barrel, secondary vacuum, electric choke and a high rise intake. my problem is, in low rpm's(1000-2500) if i stomp the gas pedal, it hesitates and pops or backfires through the carb. the timing is set at 12 degrees without the vacuum advance. im not sure if its the timing, possibly a vacuum leak, or even the intake? i just need some help. i also even thought the power valve may be blown in the carb. its a brand new carb....any help would be appreciated.
Old 07-24-2006, 06:08 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Help!
Are your valves adjusted right? Is your cam degreed? Do you have a plug wire crossed to another plug (say, 1-8-3-4-6-5-7-2)? Could be a vacuum leak in either the intake or carb, or even a bad or not-installed line.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
