Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-24-2006, 02:47 PM
curtifis curtifis is offline
No Spark
I Have a 91 Talon, I had a fender bender over 1 year ago.The car ran fine after that.I have not started it for a long time,almost a year.I tried to start it the other day,it turns over fine but no spark?Its getting fuel, the timming beltand timming are ok. I have checked all fuses,wiresand relays. Can someone tell me is there a common problem with the 91-92 2.0 moters after they sit a long time? The Battery was past dead,Ichanged that,Also I tryed to Swipe the Computer codes with an analog volt metter,I got nothing HELP!!!!!!!
Old 07-25-2006, 02:57 PM
Blaiser17 Blaiser17 is offline
Send a message via AIM to Blaiser17
Re: No Spark
Check the continuity of your spark plug wires with a multimeter
1999 Chevy Monte Carlo 3.1L
1991 Chevy Camaro 3.1L
1981 Chevy Camaro z28 383 Stroker
2000 Mercury Cougar v6
Old 07-25-2006, 03:50 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: No Spark
My guess is the coil took a dump. Did you check it to make sure its plugged in all the way?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
