Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 07-24-2006, 12:38 PM
Mr.Rivera Mr.Rivera is offline
Lo3- Distributor removal
Is there any other way to remove the distributor without removing the engine-91caprice with Lo3 in the hood.
Old 07-24-2006, 02:24 PM
Blue Bowtie's Avatar
Registered Offender
Re: Lo3- Distributor removal
Of course:
  1. Remove the distributor cap.
  2. Make a note of the position/angle of the rotor relative to the engine, and/or take a digital photo of it for reference on assembly.
  3. Remove the rotor.
  4. Remove the distributor hold-down clamp bolt and clamp.
  5. Clean the area around the distributor base on the intake.
  6. Unplug the electrical connector(s) from the distributor.
  7. Lift the distributor from the engine and tilt it forward as it clears the lifter gallery in the engine.
  8. Stuff a clean rag or something else into the hole in the intake to prevent foreign objects from entering.
There should be plenty of space to remove the distributor with the cap removed, and you may be able to do it with the rotor still attached.
Old 07-24-2006, 05:04 PM
I tryed that and it wont clear the firewall. I even had a Master Tech try to get it out and it wont come out unless removing the intake or pulling the motor forward( he said he's never seen anything like that before) Is their another method to remove the distributor?!?!
Old 07-24-2006, 06:06 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Blowtorch? Try removing one of the engine mounts and letting the engine sit lower and see if that works. Yes it's a lot of work, but not as much as lifting the engine out.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 07-24-2006, 08:30 PM
CD Smalley CD Smalley is offline
How about unbolting the trans mount and jacking it up to tilt the motor and trans forward? That should give you several degrees of tilt forward and let it come free....
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 07-24-2006, 10:12 PM
Registered Offender
Excellent point by CD. If the trans mount is worn or deteriorated, simply raising the tail housing with a floor jack might buy you enough space to get it removed. Then plan on a new trans mount soon.
