Old 08-14-2002, 02:02 AM
racer03 racer03 is offline
mini swap
hi i have an 89 honda civic dx and i was wondering if i was able to put a v-tec head on it from a 92-95 honda civic ex.
Old 08-14-2002, 02:09 AM
91civicDXdude's Avatar
it can be done but you have to drill and tap the block for an oil line. you'd be better off to get the whole d16z6 engine
Old 08-14-2002, 07:34 AM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
no no no...there's no drilling and all that for a mini-me swap..its pretty much bolt-on....you'll want to swap your car over to MPFI though.... its not too hard but I still advocate the full z6 swap over the head swap....but it does work
SOLD!
Old 08-14-2002, 08:13 AM
bobbyd bobbyd is offline
don't you have to wire all the vtec in though?
"Are you gonna bark all day little doggy, or are you gonna bite?"
Old 08-14-2002, 08:32 AM
marked001's Avatar
Moderadur
you can do it one of two ways...convert your harness over to OBD1 by means of repinning or with a conversion harness and run the p28 ecu which will control vtec and have all the proper fuel curves....or swap to MPFI and run a si ecu and use RPM activated switch to operate vtec....not too big a deal..no matter what swap you do, you're gonna have to a bit of wiring with the dx
SOLD!
Old 08-14-2002, 11:34 AM
QuickSilverEF9 QuickSilverEF9 is offline
Send a message via AIM to QuickSilverEF9
U want more power eh? VTEC to match? Swap out the d15 and swap in the d16y8!!!! It isn't a very expensive swap if you do just the basics..
1997 Golf GTI VR6
-Leather Interior
-47000 miles
-JVC KDSH707 Head Unit
ON THE WAY
-2xInfinity Kappa Perfect 6.1 components
-12" Polk Momo sub
-JBL 600.1 amp
Future
-Brock B2 deep dish wheels
-Suspension.....
Old 08-14-2002, 12:58 PM
i was always told that if you're putting the 1.6 head on 1.5 block you have to drill and tap for the oil line but if you're putting 1.6vtec head on 1.6 non vtec block it will bolt right up. sorry if i was misled and gave you false info
