Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 07-24-2006, 09:05 AM
djmann02's Avatar
djmann02 djmann02 is offline
Question 99 Wrangler axle ratio
I have a 99 Wrangler Sport. I am interested in knowing about the axle ratio in this Jeep. I have gotten mixed specs as far as the axle ratio goes. Does anyone know the factory axle ratio or can advise me where to look for a code that will tell me?
Old 07-24-2006, 01:03 PM
myjeepsux420 myjeepsux420 is offline
Send a message via MSN to myjeepsux420
Re: 99 Wrangler axle ratio
Just look at the metal tag on the outside of the diff cover. What size engine does your jeep have?
1995 Jeep Wrangler
3 1/2" lift 33x12.50 tires
4.5L stroked I-6
Bored throttle body & Cold Air Intake
Jet Chip Stage 2
Jet Thermostat
Colorado Off Road Rig!!!
Old 07-24-2006, 02:27 PM
Ray H Ray H is offline
As stated above, there is a metal tag on the diff cover that has the ratio on it. It will probably be either 3.07 or 3.73 but may possibly be 3.55. If its an automatic it will have 3.07s, if its a stick it will have either 3.73s or 3.55s.
Old 07-24-2006, 02:50 PM
djmann02's Avatar
It is the 4.0L with a 5 speed. I didn't know about the tag. I will go check on that right now. Will let you know what I find.
OK, just checked the tags. To my surprise, the Jeep is equipped with 3.07 gears. Go figure. Thanks for the help with the tag. But why do you think they put such a high geared rear end in a manual transmission?
Old 07-24-2006, 06:04 PM
That is a little surprising, but Jeep does some odd things sometimes. Glad you found out what it has though.
Old 07-25-2006, 01:26 PM
Here's my guess. The 3.07 is the std ratio for the 6-cyl manual tranny. The 3.73 is the HD towing package for the 6-cyl manual tranny. The 3.55 is for the 6-cyl auto and the 4.10 is for the 4-cyl.
1995 Jeep Wrangler
4.5L stroked I-6
Jet Chip Stage 2
Jet Thermostat
