Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 08-14-2002, 01:09 AM
jimmyfunk's Avatar
jimmyfunk jimmyfunk is offline
Send a message via AIM to jimmyfunk
T3? or T4?- for custom setup
i've heard that the T3 turbos and sometimes T4 are the best way to go when doing a custom setup. What cars come with these turbos factory installed? I've found a junkyard list with the cars that have factory turbos.....but I'm getting names like....Garrett TB3043 or Mitsubishi TD05 or Garrett TB3063. I'm assuming that those two Garretts would be "T3" turbos by the name??? .....but I'm not sure....any help? How can I distinguish the difference??
GO BIG PAPA!
aim: XjimmyfunkX
Old 08-14-2002, 07:40 PM
Tominos Tominos is offline
t4 on a d series motor would be way too big. the d series doesn't have enough exhaust pressure to power the t4, so you'll have major turbo lag, and boost will only come on at redline.
Old 08-23-2002, 04:36 AM
Whitey001 Whitey001 is offline
Not sure on the numbers but if u were to go with the t4 id reccomend nos to reduce the lag time of the turbo:greenchai
Old 08-23-2002, 04:30 PM
jimmyfunk's Avatar
i've heard that T4 would be a little larger than what I want for my application
GO BIG PAPA!
aim: XjimmyfunkX
Old 09-02-2002, 12:20 AM
u know if they make a t3/4 hybrid for that car:greenchai
Old 09-02-2002, 05:36 PM
Self's Avatar
Self Self is offline
Send a message via AIM to Self
Turbo's are completely universal. Any T3/T4 turbo will generally be the same and work just fine. When you hear talk about turbo setups made for specific vehicles, they're talking about the KIT, not the turbo itself. Kits are made for certain vehicles, and contain piping, brackets, hoses, and other accessories that make installing the turbo on that specific car MUCH easier. But you could theoretically take ANY turbo from ANY car and custom fabricate all of the necessary accessories and make it work on your car. So yes, ANY t3/t4 hyrbrid turbo would work for that car. The problem arises when you start talking about what you're going to need to install the turbo and make it work properly.
There's no replacement for displacement...No, not even a turbo.
Old 09-07-2002, 10:43 PM
Rice_destroyer Rice_destroyer is offline
if you're gonna run this turbo on your SOHC, better stick with the T3. even with the T3 there's still a little lag on my car. i bet you'll probably lag up til 25k + on yours even with a T3. still though, good luck. once you're done, you'll love the PSSSHHH sound.:smoker:
94 SI, B18B1, port n polished head, SRP 9.2 slugs, Eagle Rods, Total Seal rings, ARP bolts, Nuformz blockguard, MSD ignition, apexi V-AFC(hack), PYR chip(8500 redline), 450cc injectors, bbk f/p, custom T3 kit w/MP equal length manifold, huge intercooler, restrictive 2 1/2' exhaust
next mod: Hondata+GM MAP
