Go Back   Automotive Forums Car Chat > BMW > 5 Series
Old 07-23-2006, 09:23 PM
95xjsport 95xjsport is offline
Send a message via AIM to 95xjsport Send a message via Yahoo to 95xjsport
'92 525I transmission fluid
I have a 92 bmw 525I and the tranny leaks a bit. I was told the tranny was sealed where only a dealer could add fluid but, under the hood I found a resevoir labled aft oil only. whats in looks and smells like tranny fluid plus it is even low. can I add transmision fluid to it? what kind? just plain atf? or does it need a specila expensive fluid like my vw jetta does?? someone let me know asap, thanks in advance...
Black 99 Jetta GLX VR6
Black 92 BMW 525I
Blue 95 GMC Jimmy SLT 4.3L VORTEC V6 (Sold... Junk)
Green 98 Jeep Cherokee SE (totaled Electrical fire)
Red 95 Jeep Cherokee Sport (Gone)
Green 93 Jeep Grand Cherokee Limited (for sale)
[email protected]
"Racing a ricer is just like competing in the special olympics, even if you win your still retarded"
Old 07-24-2006, 05:10 PM
Antiburn's Avatar
Antiburn Antiburn is offline
Send a message via AIM to Antiburn
Re: '92 525I transmission fluid
The container labled "AFT" is your power steering fluid resivior. Its in the front left of your enging bay correct? If that is low then I would still top it off. You can use AFT fluid to top it off with.
Your tranny is a different story, theres a fill and drain plug on the left side of the tranny, a size 17mm plug. Its directly under the drivers seat. To check your fluid you need to be on level ground so no ramps, jacks stands could work but try to make the car level. Your best bet is a car lift or alignment rack. When you fill it up it should start dripping out of the higher hole, then you know its filled.
Old 07-24-2006, 05:17 PM
what kind of fluid goes into it? Do I add aft tranny fluid to it? I have fluid from my jeep atf+3 can I add that to the power steering resevoir? What type of transmission fluid does it take? I was told dexron III.
Black 92 BMW 525I
[email protected]
