Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 07-23-2006, 08:45 PM
J.S. J.S. is offline
92 cutlass problem?need advice
I got a 92 cutlass with a 3.1 motor and wanted to get a 3.4, but the 3.4 doesn't come with a tranny and I want to use the one form the 3.1. Is this possible? also has anyone had a problem swapping the two engines as far as compartment space. any help appreciated. T.I.A.
Old 07-24-2006, 06:26 AM
maxwedge maxwedge is offline
A990 racer
Re: 92 cutlass problem?need advice
Same basic engine but the electronics are different, you would need the pcm and harness to operate the engine but then the trans electronics are incompatible. If you used the long block only, swapped over your intake and all accessories, including the sensors it should work, what year 3.4? BTW, welcome to AF.
Old 08-29-2006, 03:50 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
IF the 3.4 is the DOHC engine, don't bother. They are tempermental, problematic engines. If the 3.4 is a Vin-E newer engine, you could use the shortblock as Max said, but that engine is OBD-II, so all the sensors and the entire upper end are different. They also use 2 crank sensors, your car uses 1, and a myraid of other issues that would make the swap a headache.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 08-30-2006, 10:31 PM
Thanks for the advice and the welcome. I trashed the 3.4 idea and put back in the 3.1 MPFI motor now I have another issue, well two. The first is the check enigine light won't go off. I've heard this could be for any number of reasons but It might be somthin I can pinpoint since I just installed the motor. The second thing is the temp hand is al the way in the red and the car isn't hot. This causes the check gauges light to stay on. My mechanic suggested I get an entire new dash from the junk yard. I tried to reset it by taking a srewdriver and moving the gauge but I end up breaking it. Thansk for that help too.
Old 09-05-2006, 03:35 PM
A990 racer
Welcome to AF. Start a new thread, your problem is unrelated to this thread, delete this one as you do, put in problem diagnosis. Thanks
Old 09-05-2006, 08:29 PM
fpretender38 fpretender38 is offline
Sorry Max. Thanks for the heads up. Will do.
