Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 07-23-2006, 08:39 PM
jclgodale3 jclgodale3 is offline
Speedometer gear source???
Speedo quit working in my daughters 92 Rodeo. Disconnected the cable at the tranny and spun it. Speedo moved. Pulled the speedo gear housing at the tranny and the driven gear teeth are chipped and ground up. Drive gear on tranny looks fine. Can these gears still be found at Isuzu dealerships? Or is there an alternate source? It is a 21 tooth unit. Also guessing it is a 4L30E Overdrive tranny? Thanks
Old 07-23-2006, 08:43 PM
surferfletch surferfletch is offline
Re: Speedometer gear source???
Don't forget a Honda dealer if you get desperate. I don't have a local Isuzu dealer any longer. St. Charles Automotive in MO has OEM stuff if you want to go through an Isuzu dealer.
Old 07-23-2006, 08:48 PM
I have both Isuzu and Honda dealerships close by. What would be the difference? Any? Would they still carry the gears for a 92 model? Thanks
Old 07-23-2006, 09:04 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Dealers do not bite to bad. Give them a try.
And remember dealer OEM parts only hurt one time.
If a 4L30E
There might be a chance that a GM gear would fit it.
Also some transmission shops or transmission parts places may have it.
MT
MT
Old 07-28-2006, 06:32 PM
Well, $46 freakin' dollars later for a simple speedo gear, it works again.
Old 07-28-2006, 06:40 PM
MT-2500's Avatar
AF - Advisor
Dan they did bite a little.
But look at it this way.
It only hurt one time.
MT
MT
