Old 07-23-2006, 06:55 PM
Gypsy-Stunners Gypsy-Stunners is offline
Banned
making dents
any one got a good idead make dents and crashed parts tryed heating up with lighter melted away
Old 07-23-2006, 07:07 PM
Jay! Jay! is offline
Horizontally Opposed
Re: makeing dents
The problem is that plastic doesn't behave like metal when stressed. So, unless you're building a Saturn with plastic body panels, it can be tricky.
Conceptually, the best method I've seen was in the tips column of some old Scale Auto. It involves foil casting the panel to be damaged, but warping or deforming the foil mold to represent the damage, and then casting a replacement panel. You use heavy foil, like kitchen foil, so it will hold it's general shape, and the casting agent can be whatever works - most resins may be too thin to stick to a 1-piece mold of a complex shape.
Hierarchy of Subaru:
(Click to see mine!)
Old 07-23-2006, 10:17 PM
druid_99's Avatar
druid_99 druid_99 is offline
Re: making dents
What I used to do is not by using lighter because it did not have constant heating. Too near and it will melt and too far the plastic just won't bend. What I use is the lighter which uses filament rather than the traditional types. Candle fire is also a no-no.
I usually will heat it bit by bit and making sure that the plastic will be soft and not melt. Then I will push it using erasers to make the dents. Here's an example of the dent that I made using the mentioned method on the front left fender and the front bonnet.
What is understood need not be discussed
Old 07-24-2006, 12:38 AM
Banned
Re: making dents
thanks for the feed back am building a 69 GTX 440 Pro Street and my paint job went on the sour side so now am ended up maken it a crash test car thanks for the info soon to put pics up thanks
