Go Back   Automotive Forums Car Chat > Lincoln > Navigator
Old 07-23-2006, 04:37 PM
hflyboy hflyboy is offline
Transfer case fluid surprisingly burnt smelling
My 1999 Navigator 4X4 has 105,000 miles and while I was replacing the fuel pump recently I noticed the transfer case output shaft seal was leaking. Today I replaced the seal with an OEM replacement from the local Ford dealer (about $23) and also did a fluid drain and refill with Mercon. The old fluid was surprisingly brown and burnt smelling. I rarely use the 4H and 4L features, but the automatic feature of the unit must be applying the clutches more often than I would have thought. I regret not having changed the fluid sooner. I'm posting this for the benefit of those who haven't given the transfer case fluid a thought.....
Old 07-24-2006, 12:17 PM
Bannedonce Bannedonce is offline
Banned
Re: Transfer case fluid surprisingly burnt smelling
after 100000 miles i think you should have changed it more than once
Old 07-24-2006, 04:39 PM
You're a troll. Your opinion is meaningless, and my maintenance schedule is none of your business. I'm hoping you'll be bannedagain soon.
1999 4X4 Navigator
105,000 miles
Old 07-24-2006, 05:17 PM
blazee's Avatar
blazee blazee is offline
Problem?
