| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
Coolant Issues
My motor runs fine before the coolant warms up to operating tempeture. It begins to run rich after it warms up. What is going on?
I was thinking a disconnected ECT sensor. |
are you sure its because the coolant warms up? could it be running rich cause the engine is getting hot?
i really dont know much about that, but maybe the coolant system need flushing? just a shot in the dark...
I am pretty sure it is your O2 sensor. There is a getto but effective way to fix it but I am not recommending you to do it, so just replace it will a new one.
PS. How old is your O2 senor anyway?
Power is nothing without control The fastest driver is the one with skills 95 Civic EX 83 Toyota Starlet 07 Ducati Monster S4RS |
Going to have to figure out what is causing this... Just re-placing the O2 sensor well not fix the prob. In most cases, it will just turn around and foul the new one... hehehe
Have a look at the timing and cam/crankshaft alignment. It may be running a little to retarded, causing the rich condition. Or the fpr is failing on you, allowing to much pressure to build. As far dis-connecting the ECT sensors goes. That will not solve the problem, chances are it will create a whole new set of performance issues of cold starts ect.... Go here if you want to go ahead and check-it tho.. http://geocities.com/chipman_13/sens...-shoot.html#TA "Noth'in like Induction..." ![]() -Ryan-
88' CRX Si - JRSC @ 6psi Z6 Mini-Me, JDM SiR Conversion NOS #5122, JR Liquid InterCooling System ZYDNE SECU, 450's B&M FP Set, B&M Command Flo AutoMeter - Phantom FP, A/F, N2O, Boost gauges & pods, ARP HSKit, AEM Pads, 87' HF Drums, DYI CAI |
