Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 07-23-2006, 11:59 AM
xrtdx8's Avatar
xrtdx8 xrtdx8 is offline
Send a message via Yahoo to xrtdx8 Send a message via Skype™ to xrtdx8
Question 2001 5.9 first to second shift problem
here's the deal the other day i pulled out of a gas station and put the pedal to the floor, wasn't paying attention to the RPM's and and next thing i know i'm bouncing off the rev. limiter, as soon as i let off a little bit it shifted to second. So later that day I figured i would see if it would do it again, and it did.
I haven't tried it again to see if it was still doin it.
Does anyone know what would cause this problem?, Thanks
Old 09-29-2006, 06:25 PM
Elizabeth0365 Elizabeth0365 is offline
Re: 2001 5.9 first to second shift problem
I read that it could be the Governor Control System... the Governor Solenoid and the Transducer...
Old 09-29-2006, 09:21 PM
hondahappy86 hondahappy86 is offline
or have your trans fluid and filter changed....just check
Old 06-10-2007, 11:09 AM
cherry01 cherry01 is offline
speed sensors, inexpensive and easy to fix. do both, 1 on the rear pumpkin and 1 on the trans. buy them at an auto parts store. once you see what they look like they will be easy to spot under the truck.
