Old 07-23-2006, 01:59 AM
soccrplayrGTP soccrplayrGTP is offline
Send a message via AIM to soccrplayrGTP
bringin out the true brains for this one.. brakes locking up
vehicle:
2000 Safari 2WD
the vehicle drives normal until 5-10miles of driving, about 5 min after vehicle is up to temp
problem:
ALL 4 BRAKES LOCK UP!
slowely then eventually you dont go anywhere. You dont have to hit the brakes hard, often, whatever it just happens.. let it sit and cool off for 4 hours and come back and drive it for another 15-20 min BOOM STUCK AGAIN!!
grrrr and I checked all corners, every wheel (vehicle secured but in neutral) does not spin..
Recent repairs.. new master cyl. and booster
Please help me
Old 07-23-2006, 06:26 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: bringin out the true brains for this one.. brakes locking up
Why was the booster and MC replaced?
I had one do this and found that the brake fluid was contaminated with PS fluid (thanks Jiify Lube).
Very expensive repair!
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 07-23-2006, 07:46 AM
manmac manmac is offline
: i am not an expert,but if the system had P S fluid in it ,everything has to be drained all the way to the brakes,and if [jiffy lube] did it they are responsible and liable for the cost to repair.:
Old 07-23-2006, 10:08 AM
maxwedge maxwedge is offline
A990 racer
Originally Posted by soccrplayrGTP
vehicle:
2000 Safari 2WD
problem:
Please help me
As GMMerlin asked why was the original work done? These are typical symptoms of the rod from the booster to the master too long or misadjusted or an internal leak in the booster gradually applying the brakes.
Old 07-23-2006, 11:54 AM
yeah ill have to flush the entire system today... go from there?!?!?!
and I was thinking maybe a faulty new booster.. I am not sure why the original work was done to begin with, not my vehicle im just the laborer now
Old 07-23-2006, 03:19 PM
my alldata told me there is a Fluid pressure sensor/switch... anyone know what that controls EXACTLY other than the obvious?
Old 07-23-2006, 04:48 PM
A990 racer
Look on the proportioning valve under the M/C.
Old 07-25-2006, 01:30 AM
the booster rod is too long ill keep ya posted..
Old 07-29-2006, 09:16 PM
ok well I measured 1/4" of gap I put between the booster and the master by backing off the 15MM bolts that hold the two together.. I dont know where this guy had his work done but they screwed up.. I measured and took out the rod, cut it, reground the round tip to it and reinstalled everything...
Works perfect.. gave it back to him the other day and its been running great, brake free while accellerating, for 550 miles or so now
Thank guys for the suggestions, ill be stickin around for a while
