| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
instaled FMIC today.
i got done today at arround 3, evertyhing went pretty smooth except the part where the outlet side of the turbo needs to be hooked up to the IC,, there was no way it would be a direct bolt on, so i had to use my LICP, no i just a few questions.
this goes to the people here with the same kit. how did you run the pipes? i put mine under the crossmember thing "for now". Also, i still have a big ass boost leak i think, the turbo spools up fine, and boost like normal, but when i hit 15 psi, it starts jerking and acting like boost leak,cant really explain it, sometimes sounds like backfire/misfire. when someone says a turbo has X shaft play, what do they mean? Today i did something to my turbo, i put my finger in the inlet side and i pushed and pulled the "fan-like-thing' and it moves , i did it up and down and it moves too, it kinda makes me think the turbo is shot because today i was boosting slowly that i could hear the turbo, and went up the RPM's slowly suddenly i heard the turbo make a really wierd(sp) noise and the car just felt like "holding back. but oohhh, it's something i gotta figure out, it's a dsm.i'll post pics when i'm done uploading, edit. pictures added ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() and last but not least.
-MODS-Autometer Boost,Oil Presure,And Water Temperature Gauges./Geddy Turbo Tmer/Eibach Sportline Springs Matched With Adjustable Iluminas 4 Corners/Konig 18" On Nitto Extreme 555/ACT 2100 PP with Street Disc/Extended Push Rod/Urethane Motor Mounts/XS Power FMIC. 28X10.5X3.5/Greedy Type RS BOV/ evo3 16g Turbo/MBC At 18PSI/Bian Crower 272 cams/SAFC2 With 510cc Injectors/Walbro 190 FP/ 1/4 mile=14.3@103MPH Last edited by 4g63gst20; 07-22-2006 at 11:29 PM. Reason: pics added |
Re: instaled FMIC today.
Sick, FMIC's are so damn sexy. As for the turbo: If the turbine shaft has play in it, its shot and either needs to be rebuilt or replaced. The jerking at 15psi could possibly be from the shitty turbo or maybe fuel cut?, not really sure.
Caleb vanilla gorilla '99 Spyder 2.4 5-speed - Red/black,14b,slow '96 Eclipse GST 5-speed - Paint www.myspace.com/ballsoutperformance |
Regarding the performance issues, well there is no doubt about it that with the T25 your car is slower now than what is was with the stock smic. The T2-small has to work ridiculously hard to keep that thing filled with air, you'll lose boost up top, and hotter air into your manifold. Backfiring could be because of that, but swap that turbo ASAP.
now - 2000 civic soon - 2002 is300
The turbo will not even notice that FMIC at high rpm. Once the IC is filled it's filled. Mass air flow through the system will not change. There is some theory that a large IC will cause more lag, but my counter theory is that the small turbos spool so friggin fast it will fill it right up anyway.
You asked a question for people with the same kit, but I don't see where you mentioned what kit this is? I don't recognize it offhand.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
sorry, i forgot to mention that, it's the xs_power one http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
-MODS-Autometer Boost,Oil Presure,And Water Temperature Gauges./Geddy Turbo Tmer/Eibach Sportline Springs Matched With Adjustable Iluminas 4 Corners/Konig 18" On Nitto Extreme 555/ACT 2100 PP with Street Disc/Extended Push Rod/Urethane Motor Mounts/XS Power FMIC. 28X10.5X3.5/Greedy Type RS BOV/ evo3 16g Turbo/MBC At 18PSI/Bian Crower 272 cams/SAFC2 With 510cc Injectors/Walbro 190 FP/ 1/4 mile=14.3@103MPH |
God that some nice looking intercooler
, BTW loose that front bumper.
GM FOR LIFE !! NEW 1997 Camaro z28 6 speed illa never going back to import , but killa alway be nice to any DSM he saw ![]() looking for 2002 Trans Am LSX UPGRATE 2010 !! 97 Camaro Z28 95 camaro lt1 1992 Pontiac Firebird v6 auto -sold - Pony 1998 Mustang GT 4.6L Manual. Black 1995 Eagle Talon TSI AWD Turbo manual R.I.P 1994 Mitsubishi Eclipse Manual gray -Sold 1997 Mitsubishi Eclipse RS Auto White - Sold |
I think you should cut down your dump tube a little bit. It looks kinda crimped. If you give it a little snip it will have a smoother shape to it.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM. 18 Inch chrome rims In closet AEM Fuel Rail, SS Lines, 1997 TSI AWD Diamonds Are 4Ever 12.7 @ 107 http://i83.photobucket.com/albums/j2...y/DSC00461.jpg |
ok so i just came back home and i was driving in a 30 mph zone doing 35 in 3rd gear, i decided to step on the clutch and rev up a litle, and WTF, i'm building boost, at arround 4.5k 10psi, so i thought the clutch was not all the way in, and when i got home in my garage, i did it again and i was still building boost, i really have no idea what this means? any ideas?
How much does the shaft on the inside move? Can you pull it out so that the blades hit the housing? Inspect the housing and blades and make sure that they aren't hitting, otherwise you're due for a new turbo and if that IS the case, I wouldn't boost anymore at all cause you run the risk of one of the blades chipping off and taking a vacation through your motor.
Awesome, I have that same fmic setup. What do you mean about how you ran the pipes? The lower pipes did not fit my turbo either. Here is a link to what I did. http://www.cardomain.com/member_page...36_39_full.jpg That pic is from looking under the front of the car. I recently bought a mandrel bent j-bend from summit but, I have not got around to installing it yet. I tested this setup up to 24psi with no leaks. I am sure it will go higher I have just not tried it yet.
95 GSX 5 speed 2.3L stroker bored .020 over Built head Bullseye/Borg Warner T04B 57 Trim Turbo RNR 3" turboback w/ o2 eliminator 255 lph Extreme Motorsports fuel pump Extreme Motorsports mbc SAFC Greddy Type S BOV FMIC (core 28x10.5x3.5) FIC 650cc fuel injectors RK Sport Fuel Pressure Regulator My Car Domain |
also, i never tried this before but yesterday i removed my intake pipe and startted the car, and noticed that the turbine wheel spins at idle, is it suppossed to do that? On something else, could the BIG FMIC give me a cell? i went to autozone and they read the codes and i got these codes. p0105- the pcm has determined that a malfunction exist in the electrical circuit for the manifold absolute pressure sensor or the barometric pressure sensor. p0110-the pcm has determined that a malfunction exist in the electrical circuit for the intak air temperature sensor, imput reading are at the extreme bottom or top of the scale, indicate a possible wiring problem.(this the one i think is because of the FMIC)(where is it located? i know it's on IM on 420a, but not sure about 4g63) p0325-the pcm has determined tha a malfunction exist in the electrical circuit for the knock sensor 1,(bank 1 or single sensor)(bank 1 identifies the location of cylinder 1,while bank 2 identifies the cylinders on the opposite bank) p1500-vehicle speed sensor intermitent. p1400-DPFE EGR circuit low input,( this one i blocked the egr),
Yes that is the stock ic piping from the lower pipe to the turbo. Like I said though, I bought a mandrel bent j pipe from summit but, since the blown head gasket issue it has not been a top priority to install it haha.
